Author Topic: PITMAN ARM INTERCHANGE  (Read 9700 times)
kdka
« on: January 28, 2006, 08:40:56 PM »
Is a 1969 camaro manual steering box pitman arm interchangeable with a '68-69 camaro power steering box?
thanks. kdka
sebastien
Re: PITMAN ARM INTERCHANGE
« Reply #1 on: January 28, 2006, 10:44:15 PM »
here'e a link that you may interect you
http://www.pozziracing.com/camaro_steering.htm#Steering
Sebastien 68  327 rag top
69 4 Speed
« Reply #2 on: January 29, 2006, 05:42:42 AM »
I think that you'll find that the output shaft on the ps unit is larger that the one on the manual steering.  If  you're installing ps on your Camaro,  you'll need a new pitman arm to match the larger output shaft.   Same goes for the rag joint.  The input shaft of the ps unit is larger than the manual as well.  I went with the longer pitman arm.  Really quickens up the steering.      J.R.
