Author Topic: Rear spoler installation and sealing  (Read 4946 times)
GaryL
  • Marilyn and me
« on: March 17, 2008, 11:11:34 PM »
What is the best method to seal the spoiler installtion? Rubber washers under the nuts? Strip caulk?
Gary
Jonesy
  • 1969 Camaro z28
Re: Rear spoler installation and sealing
« Reply #1 on: March 21, 2008, 03:03:04 PM »
Gary
I used strip caulk and dum dum or electrical sealing putty and have no problems.
I did not used rubber washers, just the factory setup.
1969 Z28 Azure Turquoise
GaryL
  • Marilyn and me
« Reply #2 on: March 21, 2008, 03:13:23 PM »
I put strip caulk under soft rubber washers on the front studs. Then a good amount of strip caulk on the front nut/washer to plug the hole from underneath. Nothing on the rear acorn nuts. I also used aluminum duct tape to cobver the emblem holes. Seems to be working after my water test.
Gary
