Author Topic: Rear Leaf Spring shock mounting plate  (Read 9776 times)
Adz28
« on: March 17, 2008, 12:22:36 AM »
Can someone confirm that the rear leaf spring shock plate for a multi-leaf (z/28) application would have a single shock support as opposed to the double version?
Thanks.
Re: Rear Leaf Spring shock mounting plate
« Reply #1 on: March 17, 2008, 01:42:30 AM »
My '68 Z/28 has the single shock version.  They're original to the car.     :)
Adz28
« Reply #3 on: March 17, 2008, 01:21:46 PM »
Thanks for the info... Same for 1969?
Jonesy
  • 1969 Camaro z28
« Reply #4 on: March 17, 2008, 03:02:20 PM »
Yes, the ones in that auction are 69 shock plates.
1969 Z28 Azure Turquoise
Adz28
« Reply #5 on: March 19, 2008, 12:17:39 PM »
Thanks again... Once installed, how much space (if any) should be between the shock plate and the axle mounts?
Steve Shauger
    • Vintage Certification
« Reply #6 on: March 19, 2008, 01:12:52 PM »
Once bolted together, the rubber pads compress and the mounting plate is flush/ no space against the axle mount.
Steve Shauger
Jonesy
  • 1969 Camaro z28
« Reply #7 on: March 19, 2008, 03:04:08 PM »
Yep, pretty much flush. I dont know if you can see it in this photo:
This photo shows space, but I loosened the bolts already:
Adz28
« Reply #8 on: March 19, 2008, 03:20:37 PM »
Thanks for the post... Nice job on the resto!
Jonesy
  • 1969 Camaro z28
« Reply #9 on: March 19, 2008, 03:26:17 PM »
thanks, it only took 10 years!!
