Author Topic: Re-Chroming original valve covers  (Read 9460 times)
gro51
  • 68 SS/RS 350
« on: March 16, 2008, 11:24:09 PM »
How good can I expect these to come out?  Can they even be done?  As you can see there is some rust in the corners and there are a few dings.  I've never had anything re-chromed so I don't know much about it.  These are original to the car so I'm really hoping they can be done nicely.
Here's the link to the pic.  I hope I did this right...
http://i78.photobucket.com/albums/j82/gro51/Picture012.jpg
Joe
Schodack, NY
'68 SS/RS 350, M21, 3:73, Rallye Green, Black Deluxe Interior
Re: Re-Chroming original valve covers
« Reply #1 on: March 16, 2008, 11:53:13 PM »
Some one will have to fix the dent by using a hammer and dolly then filing and sanding...
gro51
  • 68 SS/RS 350
« Reply #2 on: March 17, 2008, 10:20:01 PM »
Thanks.  Any other opinions?  How much you think it will cost?
Joe
Schodack, NY
sd1968z28
« Reply #3 on: March 20, 2008, 08:47:33 PM »
look for a original 1968 painted valve cover and have that chromed.  it cost me about $250 to have covers and oil fill tube chromed to show qaulity.
1968zee28
« Reply #4 on: March 21, 2008, 04:08:52 AM »
  I agree , as I just dropped off a set on 3/19 , of original "O" stamped VC's at a plater in Springfield, MA.
    (Berkshire MFG.)
  **They were not plated, but originally painted , so I had to strip the paint and tap out a couple of small dings.
   The cost is based on condition (rust / dents / *removing old plating) , which require reworking with copper plating / acid baths / labor.
    My estimate was $200- 250 for "SHOW" , with approx. 2-3 week turnaround !!
           Dave
« Reply #5 on: March 21, 2008, 12:35:03 PM »
The originals were "flash chromed" which is a very cheap process... I do not believe they use Copper...
« Reply #6 on: March 21, 2008, 04:38:20 PM »
That's correct - just nickel and chrome.
1968zee28
« Reply #7 on: March 21, 2008, 08:33:02 PM »
   Yes, I believe the originals were done at lower cost , "Flash Chroming"  over a nickle base.
    I was told that the copper process was needed to clean up surface issues, prior to polish,
    due to various surface conditions , caused by rust/dings/chrome removal , on these 40+ year old pieces of
    stamped sheet metal.
    **Also, the "Show Chrome" route is probably overkill for these covers , but they could not predict how
        they would look with the lower cost option.
            Dave
« Reply #8 on: March 21, 2008, 09:27:38 PM »
They would not be "show chrome" however they would be correct.
