Author Topic: Diverter valve question  (Read 8635 times)
Pacecarjeff
    • pacecarjeff.com
« on: March 13, 2008, 04:23:08 PM »
Just sent out a bunch of diverter valve hoods to be replated.
have always done these in Grey phosphate - to match the many original NOS, and survivor ones I have saved.
Now I see in that new book that just came out....
the color is told to be either flat black paint, or Black Phosphate???
I have 32 hoods at the plater now - I want to get these right.
What is correct?
Re: Diverter valve question
« Reply #1 on: March 14, 2008, 03:45:11 AM »
Have you looked at the restored smog systems on Jerry's site?  I don't know the difference between the grey and black, but there are several good pictures there, maybe you can tell.
Pacecarjeff
    • pacecarjeff.com
« Reply #2 on: March 14, 2008, 03:55:26 AM »
Good idea - I just looked, his are Gray phosphate too - like I thought.
I have a bunch of examples in my shop - All the unmolested ones are/were gray.
But then I saw that reference and got worried.
Make a note for the 5th edition.  :P
Gambitt
    • My car
« Reply #3 on: March 14, 2008, 12:26:33 PM »
Mine is black.
Pacecarjeff
    • pacecarjeff.com
« Reply #4 on: March 14, 2008, 12:36:18 PM »
Interesting -
The aluminum housing is pretty dark too - could it be dirt?
When i prepped the housings for the plater...
there were a few that really did appear to be black in color.
I wonder if they may have been done both ways - most of them were gray.  ???
I have more than 50 examples.
Gambitt
    • My car
« Reply #5 on: March 14, 2008, 09:28:55 PM »
There is a thin layer of engine grime on the aluminum part, but the hood is pretty clean.
m22mike
« Reply #6 on: March 15, 2008, 03:15:19 PM »
The Phosphate coating on these hoods "IMO" could vary from a lighter gray to very dark, I have seen a bunch of original and NOS ones. It was note an exact science and there probably is no one correct shade.
 I like the darker ones.
Pacecarjeff
    • pacecarjeff.com
« Reply #7 on: March 17, 2008, 07:06:46 PM »
Thanks - I am going to plate them all Gray Phosphate-
I will tell the plater to get them as dark as he can.
Most seem to be gray with a few black here and there -
but those could have really been extra dark gray.
Seems to be no real consistency in the color - just whatever was coming out that day.
Dark Gray it is.
I could always feather in some black with some paint if i had to.
Dave69x33
« Reply #8 on: March 18, 2008, 12:00:45 AM »
Pacecarjeff,
Here are a couple of pic's of my diverter valve.  They may give you a better look at the color.  FORTUNATELY, I found a complete, correctly date coded, survivor smog system including the valve, pump, hoses, hose clamps, etc.  My phosphate is a medium gray color.  UNFORTUNATELY, several years ago had an overcharged battery spew acid and spot the cover and "GF" stamp.  To say the least.....I was majorly P.O.'d.  I rubbed the unit with oil and wiped it off to prevent any further corrosion.
Hope this helps and good luck with your plating.
