Author Topic: 1969 SS hood  (Read 20548 times)
Re: 1969 SS hood
« Reply #15 on: March 14, 2008, 03:39:29 PM »
Thanks, I understand why you need them. Whats the best way to change them without killing your self?
Open the hood about 18", then stuff flat washers in the gaps between the spring coils; then open the hood all the way and the spring will fall right off. Re-install the same way.
Jonesy
  • 1969 Camaro z28
Re: 1969 SS hood
« Reply #16 on: March 14, 2008, 06:59:35 PM »
I also used the washer trick on mine.
1969 Z28 Azure Turquoise
nuch_ss396
Re: 1969 SS hood
« Reply #17 on: March 15, 2008, 01:28:00 AM »
There are a few things you should consider.  I highly doubt any GM dealer would have made a modification to the hood like that.  Of most concern to me would
be the rain coming right in on top of the engine.  With the car moving forward and the radiator fan going full out, the water pouring into those holes would be
converted into spray and subsequently totally soak the distributor, coil, and any other electrical connections against the firewall.  Additionally, the idea of cold water
( in a rain storm ) continually coming down on hot cast iron gives me the heebee-jeebees.  Chevrolet would have had a bird over these issues.........
And yes, JohnZ is correct - GM didn't design an open SS hood like this.  Oddly enough though, I believe there was a louvered hood RPO that was cancelled in 1969.
Perhaps the engineers were trying to perfect a ram style louvered SS hood, but with rear facing openings that would be pointless.
Nuch
Steve A.
z-villejw
Re: 1969 SS hood
« Reply #18 on: March 15, 2008, 02:43:57 AM »
Thanks, I'll give the washer trick a try, Never thought of that one. I've seen tools in the service manual.
J. Wiles  Southeastern Ohio
1968 RS SS Coupe with 1967 427-435 Tri-power
Tripoli Turquoise with Black Vinyl Top
4 Speed with 3:31 12 bolt
