Author Topic: Is this correct?  (Read 9575 times)
ravenspep
Is this correct?
« on: March 10, 2008, 03:26:56 AM »
Is this casting number correct for a Camaro?  And it reads 8956618 and yes, it's a "8" not a "3".  Date of 1/11/69
Thanks for your help!
Re: Is this correct?
« Reply #1 on: March 10, 2008, 04:19:32 AM »
No.  If the first "8" was a "3" it then would be one of the block casting numbers used for a '69 Camaro.
ravenspep
« Reply #2 on: March 10, 2008, 04:52:33 AM »
Paul....any idea what it belongs to?  I have been searching every where this mental midget can and I can't find this casting number anywhere.  It has the four bolt mains along with the angled bolts.
« Reply #3 on: March 10, 2008, 05:19:17 AM »
Not a clue.  My guess is if the block casting date is 1-11-69 as you state it is a 3956618 casting with a sloppy "3".  Is there an engine assemble code or partial VIN stamped on the engine pad?
lcmc
« Reply #4 on: March 10, 2008, 12:08:18 PM »
I agree with Paul. I've seen blocks this way. You would swear it is an 8 but it is definitely a 3.
Danny
1969 Z/28 X77
ravenspep
« Reply #5 on: March 10, 2008, 02:22:35 PM »
Danny...I sent a picture of the casting number and mains to your aol account.
Paul....I don't have your email addy to send you one
« Reply #6 on: March 10, 2008, 03:37:43 PM »
Angled bolts indicates an aftermarket machine shop conversion from 2-bolt mains to 4-bolt mains; the added six bolts in a factory 4-bolt setup are vertical. The casting number is 3956618.
ravenspep
« Reply #7 on: March 10, 2008, 04:35:41 PM »
John....thanks, I sent some pics to your amail addy and looks like I'm now looking for the 618 block date coded between mid Jan-beginning of Feb....thanks again!
« Reply #8 on: March 10, 2008, 07:12:10 PM »
So what is stamped on the engine pad?
ravenspep
« Reply #9 on: March 10, 2008, 11:19:42 PM »
Kurt....V0119DZ
« Reply #10 on: March 11, 2008, 02:29:25 AM »
That helps.
« Reply #11 on: March 11, 2008, 07:09:46 PM »
I'd have to see a pic to the pad, but I wonder....
Esp with the angled 4 bolt mains.
