Author Topic: 69 4-Speed shift linkage, bracket, etc. - original component finishes?  (Read 20891 times)
Hans L
Re: 69 4-Speed shift linkage, bracket, etc. - original component finishes?
« Reply #15 on: December 17, 2015, 04:18:03 AM »
Finished shifter - installed:
'69 Chevelle SS 396 4 Speed
'70 Camaro SS L78
Hans L
« Reply #16 on: December 17, 2015, 06:03:20 PM »
More - here's another picture of the shifter levers (Items 6 and 7 from the list) - you can clearly see the yellow hue for the forward shifter levers and for the Item 7 - Reverse Shifter Lever - it was dark phosphate.  No hint of silver zinc anywhere.   These are original to my Z, 04B, LA build.
« Last Edit: December 17, 2015, 06:38:17 PM by Hans L »
'70 Camaro SS L78
Hans L
« Reply #17 on: December 17, 2015, 06:08:25 PM »
Regarding these:
9. Adapter Plate bolts as best I can tell were Mag Phosphate.   After clean-up they were quite dark and did not show any hint of Silver Cad.
'70 Camaro SS L78
Hans L
« Reply #18 on: December 17, 2015, 06:11:38 PM »
And finally, regarding - 11. Shifter Body to Adaptor Plate Bolts and Washers (2 x 2) - Manganese Phosphate ?
I think the main center one is Silver Cad as best I can tell when I cleaned it up and the lower bolt is a dark Phosphate.
Here's a pic before plating:
'70 Camaro SS L78
Hans L
« Reply #19 on: December 17, 2015, 06:22:13 PM »
Here's the shifter pieces I had plated.   Can't absolutely verify they are 100% factory correct, but I had everything re-plated on the best evidence I had when I inspected each bolt and shifter piece.
'70 Camaro SS L78
Edgemontvillage
« Reply #20 on: December 18, 2015, 10:49:07 PM »
Looks good, thanks for posting Hans.
