Does anyone have pictures of original or suvivor 69 4-speed shifter linkage, the shifter mounting bracket, clutch push rod, and the reverse lockout rods? I would like to confirm the correct plating, paint color, or natural steel color, of these various components listed below. Or, can you confirm what is considered correct per judging standards.
The colors/planting I have listed below are what my originals appeared to be, but would like to confirm. If you could copy and edit my list and include the correct color or finish after each item would be helpful.
Jerry MacNeishs book, The Definitive 1969 Camaro Z/28-SS396 Fact Book, shows black and white photos of 69 Z28 linkage and levers. The levers appear to be natural steel, and I believe the 1-2, 3-4, and reverse rods were dark phosphate plated.
This is the list of items I am referring to, organized by section as called out in the 69 AIM:
UPC 7, Sec. C3, Page 112 covering Clutch Shaft & Push Rod:
Item 17 Rod #3849703
Item 14 Nut #124829
Item 18 Rod (threaded portion) #3840843
Item 1 Shaft Assy # 3899013 (bell crank) natural steel, no grease fitting but with red push in cap?
Item 9 Bracket #3932760 40-60% black gloss paint, zink dark silver or natural steel?
Item 8 (3) screws #9420603 dark phosphate?
UPC M20, Sec. A3, Page 324 covering 4 Speed Trans-Lever & Bracket Asm:
Item 2 (2) bolts #9420950 dark phosphate or zink dark silver?
Item 3 screw #9789597 - dark phosphate or zink dark silver?
Item 4 support asm (shifter mounting bracket) #9791899 natural steel?
Item 5 special nut #3955770 dark phosphate, zink dark silver or natural steel?
Item 10 & 11, shifter attachment bolts #9419062 & 454950, and associate washer and lock washers dark phosphate plated?
UPC M20, Sec A5, Page 326 covering the 4 Speed Trans-Levers & Control Rods:
Item 1 & 15, the Reverse #3955769 & the 1-2 & 3-4 Levers #9798541, natural steel?
Items 10, 11, 12 Washer, Lock Washer & Bolt #9418967 (TR head marking?) for levers dark phosphate?
Items 2, 13 & 14, the Reverse, 1-2 & 3-4 shifter rods and the associated swivels and lock nuts - dark phosphate?
UPC M20, Sec A7, Page 328, 4 Speed Trans Interlock Linkage (reverse lock out):
Items 2 & 6, the Upper and Lower Rods phosphate or natural?
Items 3 & 5, the Control Lock Idler #3955780 & Mounting-Support #3945595 silver cad, zink dark silver or natural steel?
Item 4 (2) screws #9419402 - dark phosphate, E head markings?
Thanks in advance for you input.
