Author Topic: Rick's Motor Mounts  (Read 6771 times)
Rick's Motor Mounts
« on: March 08, 2008, 10:15:18 PM »
Does anyone know if Rick's part # EP-89 motor mounts are correct for the original frame stands on a 68 Z28?  Also which through bolts are correct?  The pointed tipped ones, or the flat tipped ones?  Nuts?  Marsden or what?  Thanks.
blownz
Re: Rick's Motor Mounts
« Reply #1 on: March 10, 2008, 12:05:11 AM »
I purchased the big block mounts for my 69 Z and they did not work.  They weren't even close.  Go nosif you can.
Wayne
blownz
« Reply #2 on: March 10, 2008, 12:08:00 AM »
Sorry I read it wrong, I thought he was asking about frame mounts
Wayne
« Reply #3 on: March 11, 2008, 02:40:27 AM »
Anyone else?
RamAirDave
    • TheMuscleCarGuys.com
« Reply #4 on: March 11, 2008, 02:47:37 AM »
They aren't too specific on the 68 mounts as they are with the 69s.
They say to use the EP-90 for original frame mounts, and EP-88 for aftermarket stands.  They make no mention on the EP-89, so I would guess they work with the orginals, but don't know for sure.  Might want to call and ask.
www.TheMuscleCarGuys.com
« Reply #5 on: March 12, 2008, 04:07:44 AM »
I had gotten these years ago out of an older catalog so I should ask them which is correct again.  I guess I should ask if anyone knows where to get motor mounts that are the most correct for the 68 Z with original frame stands.  I've got some vibration and I'm trying to rule out one thing at a time.  I'd like to start with having the right motor mounts.  Thanks
