Author Topic: What date code do I need for Quadrajet for 04C 1969 Camaro?  (Read 4954 times)
sdkar
I have a 69 Camaro with a build date of 04C.  What would be the number range I would need for a correct Quadrajet for my car?  How early and how late of a carb. would be the correct one for my car.  I currently have a 7040511 QT with a date code of 0620 right next to the quadrajet number.  I also have a 7029223 - date code 2488, but it looks like the date code is on the bottom plate instead of the body.  Would the date be on on the bottom plate?
GearHead
Re: What date code do I need for Quadrajet for 04C 1969 Camaro?
« Reply #1 on: March 11, 2008, 10:46:21 PM »
Rochester-built quadrajets have a four digit julian-type code signifying actual day & year the carb was manufactured.  0620 is 62nd day of '70 & 2488 is 242nd day of '68.  My '68s carb date is on the side of the bottom plate, driver side rear.  Carter-built quadrajets had letter & year date codes i.e. D8 for April '68.
An 04C car's (April, 3rd week, 69) carb would probably be in the 1009-1159 range or 100-115th day of 1969.
'68 Camaro SS/RS 396 L35, M40, AC, Ivy Gold
