Author Topic: 67 Camaro base cp. 12 bolt posi  (Read 5554 times)
Mikey
« on: February 25, 2008, 06:45:03 PM »
Hi, I own a 1967  camaro base model with a 12 bolt posi 273!!! It has the bracket for a traction bar, no bar.   I've heard several tales on these rears, built for Z/28 road racers, left over, etccc.  My car was built in May.  Any Info or proof?? on rear??   Mikey
Re: 67 Camaro base cp. 12 bolt posi
« Reply #1 on: February 26, 2008, 03:48:52 PM »
Yes, it could possibly be original to your car. Believe it or not, there have even been a few 6 cylinders with factory installed 12-bolts. All seem to be with the 2.73 or 2.56 axle ratio.
-Jon
NHBandit
« Reply #2 on: January 21, 2009, 01:04:24 PM »
My 67 6 cylinder Powerglide car has a 12 bolt posi with 2.73 gears. No traction bar bracket.
Ron C.
« Reply #3 on: January 21, 2009, 09:20:29 PM »
what does your trim tag on the firewall have as far as numbers.can you post them.
NHBandit
« Reply #4 on: January 22, 2009, 12:05:13 AM »
Ron I'm not sure if you're asking me or Mikey but Kurt & Bertfam have all of my info. If you need it I'll have to get back to you as soon as I shovel a path to my garage...
