Author Topic: 67 Camaro Steering Column Replacement  (Read 8525 times)
gearheadtx
« on: February 21, 2008, 03:49:22 AM »
I have a few questions on the replacing my stock 67 steering column with an aftermarket one now that I have switch the shifter from the tree to the flloor.  I have a powersteering.
1.  What supplier would you recommend
2. Any issues with fit I should be aware of
3. What other parts will I need to order to make the swap work.
Mark
Brandan
  • 1969 Camaro SS 396 X-66 M22
    • 1969 Camaro 396 SS M22
Re: 67 Camaro Steering Column Replacement
« Reply #1 on: February 24, 2008, 03:50:32 PM »
Are you looking for replacement stock (with/without tilt?) or aftermarket (different style)?
NPD and Classic all sell steering columns.  You can call their tech support, they might be able to point you in the right direction.  Worth a try.
« Last Edit: February 24, 2008, 03:57:30 PM by Brandan »
Check out the 1969 ride!!!
http://www.cardomain.com/ride/676916/1
Check out the new project!!!
http://www.cardomain.com/ride/2960049
