Author Topic: What are the correct lengths for 69 Camaro side post battery cables?  (Read 4826 times)
sdkar
I would like to see if I can get the correct length battery cables for a 69 Camaro with the R-89 side post battery.   If anyone knows can you please post the correct size lengths.
sdkar
Re: What are the correct lengths for 69 Camaro side post battery cables?
« Reply #1 on: April 02, 2012, 05:15:22 AM »
I have found the answer to this question just in case anyone is interested.
The proper length for side post battery cables are the following:
Small Block (302, 307, 327, 350) - (Positive is 43-3/4") and (Negative is 34-1/2")
Big Block (396, 427) - (Positive is 45-1/2") and (Negative is 29-1/2")
The main length of the cables are black regardless of positive or negative with the "heads" that contain the bolt that attaches to the battery color coded in red for positive and black for negative.
Hope this helps.
dannystarr
« Reply #2 on: April 02, 2012, 03:01:34 PM »
Are those end to end measurements? Or cable lengths only? Or center of bolt hole to center of bolt hole?
