Author Topic: Distributor Suggestions?  (Read 7923 times)
Danos68
« on: February 06, 2008, 06:36:38 PM »
I have a 1970 LT-1 Corvette motor in my 68 SS350 Camaro. It was rebuilt to stock LT-1 specs with the exception of a hydraulic cam. Any suggestions on an aftermarket distributor and ignition system in order to gain some performance?
hotrod68
  • almost finished
Re: Distributor Suggestions?
« Reply #1 on: February 07, 2008, 06:17:57 AM »
I've used an electronic Pertronix distributor and it works great. It has the small black cap and vacuum advance canister so it looks stock but without the points, and I also used the black Pertronix 7mm plug wires. It's also super simple to wire the thing into a hidden MSD box. It's the GM transistor ignition on steroids..lol. My 2 cents.
dd442
  • Gotta Love a Big Block
« Reply #2 on: February 07, 2008, 03:10:08 PM »
He's right that works great, But if you dont care about the stock look I would go with MSD Dist, Coil,Wires, And Ing Box.(6A,6AL). MSD designs all of its products to work with each other. If its Performance you are lookin for. If its the stock look I would go with the Petronix Like he said.
70 SS 396\350, 69jane, 69 442, 70 Mach 1
Danos68
« Reply #3 on: February 07, 2008, 09:41:02 PM »
Thanks for the suggestions guys, good info.
pdq67
« Reply #4 on: November 27, 2009, 03:53:58 AM »
Until THEY drop a neutron bomb and destroy all electronic crap!
Point Dizzy by me!  And, He, He, real copper wires and ta hell w/ the neighbors.
pdq67
