Author Topic: 1968 Z-28  (Read 38230 times)
Re: 1968 Z-28
« Reply #15 on: January 27, 2006, 09:52:14 PM »
Evidense of Z-28 stripes in trunk lip and hood lip or in cowl? Under all the repaint? 4 piston calipers on front? 12 bolt rear? 3/8 fuel line from the tank? What shifter? Original colors, int and ext.? Other options? Let's have it with a full description! The casting no. will only tell you it "could" be a 302, could also be a 327. Look to the stamped no. in the front. Better yet, get the book Chevrolet by the Numbers and start from scratch, carb, water pump, intake, distributor, etc.
garve
Re: 1968 Z-28
« Reply #16 on: January 27, 2006, 11:48:52 PM »
Can anyone tell me exactly where to look for the "MO" engine code? Thanks.
Re: 1968 Z-28
« Reply #17 on: January 28, 2006, 02:49:05 AM »
The engine source, assembly date, and identifying suffix code is stamped on a machined pad on the front of the block immediately below the front of the passenger side cylinder head; the "MO" suffix will be the last two characters of the stamping, which will look like "V0306MO".
garve
Re: 1968 Z-28
« Reply #18 on: January 31, 2006, 12:20:07 AM »
O.K. I finally got to check the block that is rumored to be from this car. Here are the #'s from the block, the cowl tag and the vin.
cowl:        06B                         H257
         ST  68-12437  LOS 42128 BODY
         TR 722                     G-G PAINT
V.I.N. 124378L343505
ENGINE: V0423MO    18N425549
Could this be the original block??
Re: 1968 Z-28
« Reply #19 on: January 31, 2006, 01:40:25 AM »
cowl: 06B H257
 TR 722 G-G PAINT
No, that engine was originally installed in a '68 Norwood car, VIN #425549; your car was built at Van Nuys.
Rich
  • 68 L30/M20 RS
Re: 1968 Z-28
« Reply #20 on: February 01, 2006, 03:52:48 AM »
Document *all* the clues in existing state with detailed digital photos *now*; especially the glovebox sticker and the partial VIN on the Muncie tranny (that will be priceless if you have no other original document and the engine block was switched).  Attempt a title search.  Attempt to locate and get statements from people that knew that car when it was new.  And look for (though don't expect) broadcast sheet info in the car as you restore it.  You should be able to build a convincing story.
68 L30/M20 RS
bjr68z28
Re: 1968 Z-28
« Reply #21 on: February 02, 2006, 07:03:04 PM »
Rich,
I have been following this thread with high interest.  I have '68 Z with original engine, trans. rear end etc, but no paper documentation except tire pressure sticker.  I do however have signed statement from the original owner, after the car was recognized online by a friend of the second owner.  (Actually met him today)  My question, would you like me to send the information I have for the CRG data base?
Bill
Rich
  • 68 L30/M20 RS
Re: 1968 Z-28
« Reply #22 on: February 04, 2006, 01:40:24 AM »
Absolutely.  Please see other threads on submitting data.  Thanks, Rich
68 L30/M20 RS
bjr68z28
Re: 1968 Z-28 Info for Data Base
« Reply #23 on: February 05, 2006, 08:30:33 PM »
Rich & Kurt,
Here is the info I have.  The Z was purchased Sept. '68 from Vaughn Chevrolet, Lynchburg Virginia.  As mentioned in prior post, I have spoken to the first and second owners.  Thanks to all CRG staff for their great work.
Bill
VIN 124378N479958
Trim Rag:   07D
                ST 68-12437      NOR 180991
                TR 714              UU
Engine:      18N479958        VO718MO
Axle is BV code (4:10)
Muncie M21 with matching partial VIN
E 70 X 15  Tire Pressure Sticker is intact.
