Author Topic: 4-Speed Hole  (Read 23851 times)
dd442
  • Gotta Love a Big Block
4-Speed Hole
« on: January 22, 2008, 08:44:36 AM »
Does anyone have the Dimensions or Pics of where the Hole for the 4-speed goes in the floor tunnel? I have replaced the whole floor pan and dont want to do a hack job(cut a square hole) any suggestions would be helpful. Thanks
70 SS 396\350, 69jane, 69 442, 70 Mach 1
Re: 4-Speed Hole
« Reply #1 on: January 23, 2008, 01:10:07 AM »
If someone doesn't here, go to www.camaro.net.  Someone there posted a template a while back.
x77-69z28
Re: 4-Speed Hole
« Reply #2 on: January 23, 2008, 10:56:10 PM »
the original hole looks like it was cut with a torch.
dd442
Re: 4-Speed Hole
« Reply #3 on: January 24, 2008, 01:42:19 AM »
I have a Plasma Cutter I could use if that is the case, but I will probably still clean it up to look neat.I will use the chrome plate as a template but im a little worried about getting the hole exact. Thanks guys, I can always count on yall for Great info.
1968RallySport
Re: 4-Speed Hole
« Reply #4 on: January 24, 2008, 03:50:10 AM »
Original manual transmission cars had a stamped hole that left a "lip" approximately 1/8" wide that was directed downward for rigidity.
wtexz10
Re: 4-Speed Hole
« Reply #5 on: January 24, 2008, 04:24:09 AM »
I disagree about the stamped hole.  Check the threads on this site.  Mine and everyone I've ever seen is torch cut.
69 Camaro Z10.. 72 GMC C1500
79 Mazda RX7.. 79 Trans Am WS6
06 Corvette Z06.. 10 BMW 650i
dd442
Re: 4-Speed Hole
« Reply #6 on: January 24, 2008, 08:39:00 PM »
What threads are you speaking of?
Gramps69Z
  • 69 X33 D80
Re: 4-Speed Hole
« Reply #7 on: January 24, 2008, 09:19:31 PM »
Past threads of the subject.  This was brought up before.
Captain John Wykoff
Re: 4-Speed Hole
« Reply #8 on: January 24, 2008, 09:31:54 PM »
I've always been under the impression that 69's were torched, and 68's (and I belive 67's also) were stamped.
« Last Edit: January 24, 2008, 09:36:44 PM by bertfam »
x77-69z28
Re: 4-Speed Hole
« Reply #9 on: January 24, 2008, 10:57:53 PM »
i havent seen my 67 in a while, but my 69 is definately torch cut. what year were we talking about?
RickH
Re: 4-Speed Hole
« Reply #10 on: January 25, 2008, 03:41:32 AM »
The 1969 manual shifter hole in the tunnel was torch cut. In 1967 the hole for a floor shift whether manual or automatic was pressed cut and was reenforced. I believe 1968 was the same as 1967.
Rick H.
rs/ss camaro collector
Re: 4-Speed Hole
« Reply #11 on: January 25, 2008, 07:59:38 AM »
all 1967 and 68's i have owned and restored were Air chissled from the factory from the top. leaving a edge  about 1/8 down toward the ground. I am not familiar with the 1969. Hope that helps
brent bridgeman
current projects: 1968 SS 396/AT w/A/C All #'s Matching...............1967 RS convertable 327/Powerglide..............1967 RS coupe 327/AT...............1967 Pro Street Camaro
dd442
Re: 4-Speed Hole
« Reply #12 on: January 25, 2008, 10:29:05 AM »
It is a 69, and thanks to all of you, I learn something new all the time. I was a little confused because I have owned a few 67's and 68's and the four speed cars looked to be pressed cut so I thought that so was the 69.  So Thanks for clearing that up.
Re: 4-Speed Hole
« Reply #13 on: January 25, 2008, 07:57:54 PM »
68 was pressed and had the reinforcement ring on the bottom of the hole (under the car).
1968RallySport
Re: 4-Speed Hole
« Reply #14 on: January 28, 2008, 12:40:37 AM »
factory location of manual transmission shifter for a 1968 Camaro
