Author Topic: 67 CAMARO TRANSMISSION CODE OMITTED ON COWL TAG  (Read 8282 times)
MARINA67RS
« on: January 16, 2008, 08:44:16 PM »
CRG Members -
I have a '67 Camaro RS Convertible.  Group 2 on the cowl tag shows the alpha character, "G" and that's it.  The car does indeed have a console, but no transmission character.  The car originally came with a 327 and according to the second owner, a manual transmission.  My understanding is that a 67 with a 327 would have come with a Saginaw 3 or 4 spd, rather than the Muncie, however no code was stamped on the cowl tag.  Has anyone seen a cowl tag missing the trans code?  Does it mean something by virtue of the trans code being omitted?
The rest of the build plate matches the rest of the car, including the L in Group 3 for RS, the exterior and interior trim colors, top color, etc.
Incidentally, the speedo cable comes out the front near the brake booster and not near the gas pedal /tunnel as with a big-block car.  My understanding is the powerglide and Saginaw transmission shared the same speedo cable hole in '67.  My understanding is the same hole was cut in the floor regardless of floor-shift transmission type in '67 as well.
Any ideas?
Thanks in advance-
Doug
Re: 67 CAMARO TRANSMISSION CODE OMITTED ON COWL TAG
« Reply #1 on: January 17, 2008, 09:26:13 PM »
Doug,
No trans code indicates it came with a 3 speed manual trans.
kid56
« Reply #2 on: February 07, 2008, 06:45:44 AM »
Hi, I have been reading your post, I also have a car with no trans code
It is a 67 ss/rs 396
E 2G 3L 4N the trans was gone when I got this car in 83 the old owner said it was a 4 speed car .
did they make a ss396 with a 3 speed manual trans?
wasnt there a code for a 3speed manual a B i think?
 thanks for any help
Mike B
« Reply #3 on: February 07, 2008, 08:48:26 AM »
Originally, it was also a 3-speed manual car. Not common in a 396, but it was the standard transmission.
ccargo
« Reply #4 on: February 07, 2008, 12:54:57 PM »
Could this not have been an early built TH400 car Kurt?
67 O-1 O4A L35 Convertible, Indy Zone IPC
« Reply #5 on: February 07, 2008, 07:05:40 PM »
Pat,
Thanks!! That's what I get for not thinking!    ::)
Yes, it could have been a TH400 car.
A pic of the tag / the rest of the tag info would help tell us more.
« Last Edit: February 07, 2008, 07:08:09 PM by KurtS »
Farm Boy
« Reply #6 on: February 08, 2008, 12:52:25 AM »
I also have a 1967 “2G” car. It came with a console and a 3 speed manual transmission.
I believe Fisher Body trim tag option codes indicate changes that are different from a standard body build at the Fisher plant. The funny thing is there is not one single difference between a “2G” body and a non SS “2LG” body.
