Author Topic: 69 Interior question  (Read 6606 times)
jdv69z
  • 69 RS Z/28 52E
« on: January 16, 2008, 05:11:09 PM »
What option/options included the assist grip and molded plastic trim on the passenger's side? Was this Z23? And on all Custom interior cars, ie Z87? I have noticed cars without these items, and the Camaro emblem mounted above the glove box door, where it is moved more towards the center of the interior when they (assist grip and molding) are included, since the assist grip is above the glove box door.
I assume any Camaro could be ordered with these items if not already included as part of another option?
Jimmy V.
Jimmy V.
Re: 69 Interior question
« Reply #1 on: January 16, 2008, 06:07:18 PM »
The assist grip and plastic backing plate (on a painted dash) were part of Z23 Special Interior, along with bright pedal trim, wood inserts on both sides of the lower cluster and on the steering wheel shroud. Z23 was included in the Z87 Deluxe Interior option.
jdv69z
  • 69 RS Z/28 52E
« Reply #2 on: January 16, 2008, 08:55:54 PM »
That matches my 69 Rally sport with standard interior. It has bright pedal trim, assist grip with the backing plate, and woodgrain trim only on both sides of the steering wheel but not all the way across the passenger side. That was part of the custom interior, I'm assuming. It also has wood grain steering wheel shroud/center with RS emblem.
Thanks, I'm amazed at the different possible trim/option combinations that were available and sold on these cars.
Jimmy V.
Jimmy V.
danimaldds
« Reply #3 on: January 24, 2008, 07:37:07 PM »
So where does the camaro emblem go, with the assist strap in place??Pic??
Dr. Dan Mairani.  ..1969 ss 350 Lemans blue/black
jdv69z
  • 69 RS Z/28 52E
« Reply #4 on: January 24, 2008, 08:03:41 PM »
On a Camaro without the trim piece and assist grip handle, it mounts above the glove box door. With the trim piece, it mounts more towards the center closer to the ash tray. Look at different Camaro pic's with different interior combinations, and you'll see the two different positions.
Jimmy V.
Jimmy V.
danimaldds
« Reply #5 on: January 25, 2008, 02:14:45 AM »
thanks guys!!
