Author Topic: Flashing Check Engine Light  (Read 7615 times)
2001 Camaro SS
« on: January 12, 2008, 06:38:17 PM »
A flashing check engine light appears on the dash of my 2001 Camaro SS.  I looked in the owners  manual and reads that there has been a misfire condition has been detected.  My mechanic of long time just relocated and I have no idea where to start.  Any suggestions on what the problem can be.  I'm thinking spark plugs and spark plug cables.  Any feed back is greatly appreciated.   Thank you.
z-villejw
Re: Flashing Check Engine Light
« Reply #1 on: January 13, 2008, 11:43:52 AM »
Stop by Autozone & have them put it on the scanner. Maybe something simple.
J. Wiles  Southeastern Ohio
1968 RS SS Coupe with 1967 427-435 Tri-power
Tripoli Turquoise with Black Vinyl Top
4 Speed with 3:31 12 bolt
dd442
  • Gotta Love a Big Block
« Reply #2 on: January 16, 2008, 02:02:31 AM »
When was the last time your plugs and wires were changed?
70 SS 396\350, 69jane, 69 442, 70 Mach 1
dd442
« Reply #3 on: January 16, 2008, 02:07:37 AM »
Also, Have you ever had your injectors cleaned? you could also have a injector problem
