Author Topic: 1968 z28 speedo clips  (Read 11326 times)
fireZ
« on: January 06, 2008, 09:38:30 PM »
I am doing some detail work on my 68 Z28.I can see were 2 speedo cable clips are but all the suppliers say 3 are required per car. I can see one located about 2 inches from were the cable exits the firewall and the other one is in the trans tunnel. Where would I look for the third clip?
1968 Z28 LA Built
LIC # RPO Z28
sd1968z28
Re: 1968 z28 speedo clips
« Reply #1 on: January 07, 2008, 02:47:27 PM »
i think there are only 2?
fireZ
« Reply #2 on: January 07, 2008, 04:37:44 PM »
Thats what I think to but hard to see with car on the ground. DR classics book says 3 per car. I will try to look in an assembly manual. Thanks Paul
1968 Z28 LA Built
LIC # RPO Z28
mark x22
« Reply #3 on: January 07, 2008, 11:13:24 PM »
fireZ
« Reply #4 on: January 08, 2008, 12:56:31 AM »
I cant thank you enough for the picture . Good info.
1968 Z28 LA Built
LIC # RPO Z28
« Reply #5 on: January 11, 2008, 05:17:26 AM »
There are 3
deejaygee
« Reply #6 on: January 11, 2008, 06:09:40 AM »
Here are some photos of my 67 Z cable intallation. I count only 2 clips. Click on the yellow arrows on the diagram to see photos:
http://67z28.com/project/images/ImageMap.html
Pex68
« Reply #7 on: January 11, 2008, 03:09:03 PM »
Not sure if Z-28 differs from BB SS but there are 3 on mine.  See below.  The one right outside grommet is missing but you can see the hole, second is right the entrance to trans tunnel (partially blocked by end of ground strap) and third is deeper in trans tunnel right before cable makes bend to go to trans.
Hope this helps!
Chris P
« Reply #8 on: January 11, 2008, 08:09:56 PM »
As your pic says, "see sheet A6", it shows the three clips.
fireZ
« Reply #9 on: January 11, 2008, 09:06:06 PM »
Thanks for the help guys, just a small detail but important to me.
1968 Z28 LA Built
LIC # RPO Z28
Pex68
« Reply #10 on: January 11, 2008, 09:10:43 PM »
No detail is too small...
Chris P
« Reply #11 on: January 12, 2008, 02:19:37 AM »
No, and fortunately, when one of us is missing something original, another person may have that and be missing something we have original.  Put us together, here, and voila.
fireZ
« Reply #12 on: January 12, 2008, 08:51:39 PM »
That the greatest thing about this site. Guys will share information.
1968 Z28 LA Built
LIC # RPO Z28
