Author Topic: 69 front end bolt decode  (Read 9944 times)
KevinW
« on: December 15, 2007, 01:56:31 AM »
After pouring over the AIM, AMK catalog and my bolt bins, I have come up with a decode for the front end bolts for 69 at least. I started this over on TC. Anyone care to comment?
Front end bolts decoded - corrected
The front end is held together with many types of bolts. Part numbers are listed in the AIM. Pointed means the earlier style with the cut ends, not the later ones with threads all the way to the end. I will try to describe them below:
3960314 - 5/16-18x13/16” flanged, pointed
3846201 - 5/16-18x5/8” captured washer .75, flat end
3846202 - 5/16-18x7/8” captured washer .75, pointed
3853846 - 5/16-18x7/8” captured washer .75 toothed, pointed
3899538 - 5/16-18x7/8” captured washer 1.50, pointed
3847757 - 5/16-18x7/8” captured washer .75, flat end
3856065 - 5/16-18x1” captured washer .75, flat end w nut
3963329 - 3/8-16x1 3/8” captured washer 1.31, pointed
3839741 - 3/8-16x1 3/8” captured washer 1.31, flat end
Header to upper fender- 3960314; 3 required per side
Lower valance to fender extension- 3960314; 3 required per side
Fender to fender extension- 3960314; 5 required per side
Fender to firewall upper- 3963329; 3 required per side
Fender to firewall and inner fender lower- 3839741; 2 required per side (w U-nut)
Radiator support to fender and brace- 3846201; 3 required per side
Brace to fender- 3960314; 1 required per side
Fender to inner fender- 3846202 (w/o Z21) 3853846 (w Z21); 6 required per side (w U-nut)
Inner fender to Radiator support lower- 3846202; 2 required per side
Inner fender to inner fender brace – 3899538; 3 required per side
Firewall to Inner fender brace lower pass side - 3847757; 2 required
Firewall to Inner fender brace lower driv side - 3856065; 2 required
Radiator support to radiator shroud bracket - 3960314; 2 required
Valance & grill support to rad support - 3960314; 4 required
Valance & grill support to front license bracket – 3846202 assumed
Lower hood latch 3846202; 4 required
Upper hood latch 3846202; 4 required
« Last Edit: December 18, 2007, 03:41:09 AM by KurtS »
KevinW
Re: 69 front end bolt decode
« Reply #1 on: December 15, 2007, 11:33:04 AM »
Cant edit this anymore, found some additional bolts info.  Please see corrected info on TC http://www.camaros.net/forums/showthread.php?t=122781
« Reply #2 on: December 18, 2007, 03:42:36 AM »
But I could edit it. Fixed it for you. :)
KevinW
« Reply #3 on: December 18, 2007, 11:56:56 AM »
Kurt, thanks!  Is the information correct?  I was really surprised by the smaller 201 bolts for the rad support.  I always used the flanged one.  Since I sorted my bolts, I found a bunch of 201s.  That really made my day.
x77-69z28
« Reply #4 on: December 18, 2007, 09:48:11 PM »
what are the headmarkings on the 201's?
tom
    • Discount Internet Services
« Reply #5 on: December 19, 2007, 02:39:25 AM »
Kevin,
THANKS!
Tom
69 X11 Z21 L14 glide
o
KevinW
« Reply #6 on: December 19, 2007, 03:46:00 AM »
201 bolts that were still legible (not cleaned yet), were a _|_ with a small e in the middle and a M with a | through the middle.
