Author Topic: 67 rs headligts wiring  (Read 4409 times)
rkbkd
« on: December 05, 2007, 04:53:29 PM »
I recently  purchased what was sold as a rs car, the cowl tag is gone so i'm not sure.the headlight doors will open but not close.I have put 3 new relays /no change.The relays will click when turned off at switch.  Did this year have 2 different head light switches? ANY HELP WOULD BE APPRECIATED!!
Re: 67 rs headligts wiring
« Reply #1 on: December 07, 2007, 01:07:54 AM »
The headlamps must be installed for the doors to close.
RickH
« Reply #2 on: December 09, 2007, 11:34:41 PM »
Check the 4 limit switches on the core support. Make sure the diode is good. That is the brown wire from the ignition switch to headlight switch. Also the ignition must be ON for the doors to close.
Buy an RS wiring diagram. It helps.
Rick H.
