Author Topic: Help Finding Part?  (Read 11894 times)
DAL777
Help Finding Part?
« on: December 01, 2007, 03:00:24 PM »
Anyone know where to get and or part #'s for the hose, grommet, and connector for an L-48.
It is the hose that goes from the crankcase air filter in the air cleaner assembly to the passenger side valve cover near the rear.
It is on page 101,   6  C8 in the factory assembly manual.....parts # 10, 16, and 17.  I have not seen the correct parts offered in catalogs.
Re: Help Finding Part?
« Reply #1 on: December 02, 2007, 03:45:48 AM »
http://www.classicindustries.com/
DAL777
« Reply #2 on: December 03, 2007, 01:24:00 AM »
Paul,
I looked in the catalog.  All they show is an elbow and a hose.  All of the other catalogs list the same stuff.  Nobody has the connector that goes into the valve cover that the hose hooks to.
« Reply #3 on: December 03, 2007, 02:06:31 AM »
Paul,
Dal777 -
They are there.  Do a "valve cover grommet" search and you will find them.     ;)
DAL777
« Reply #4 on: December 04, 2007, 01:56:00 AM »
Still cant find the piece ("connector") that goes between the hose and grommet.
AL :)
« Reply #5 on: December 04, 2007, 03:59:12 AM »
AL :)
DAL777 -
The "connector" (as per the AIM) I believe you are looking for can be found be doing a "air cleaner elbow" search.     :)
DAL777
« Reply #6 on: December 07, 2007, 10:53:17 PM »
If you look at the picture, it is not an elbow.   (You can buy an elbow)
It is a straight piece.
9T4Z
    • Gary's Camaro
« Reply #7 on: December 09, 2007, 01:59:02 AM »
Dal..   the connector to the valve cover IS a 90 degree elbow that fits into the grommet on the pass rear valve cover.  Be careful of what hose you order.  There is a hose there for the cowl inducted air cleaner that has less of a curve to it.
You can find these parts at Ricks as well.
good luck
Gary 9T4Z
94Z rag blower 491 rwhp (now 505!)
69 Pace Car, 70RS,91Z,91RS
Camaro Billy
    • 1969 RS/SS
« Reply #8 on: December 09, 2007, 02:52:40 AM »
Dal,
You are correct, it is a small straight connector as it is shown on page 101 of the '69 AIM.
Here is a shot of mine, you can't see the connector but it is like the one in the AIM. I could not find anywhere to buy it repop and after about 9 months of searching I found an orig. one at  Calisle for $1.00. I know someone who found a hose at the auto parts store that matched pretty well and just cut the bottom off the 90 degree tube to make the connection.
Billy
1969 RS/SS 350/300 Rallye Green . Black Vinyl Top
DAL777
« Reply #9 on: December 09, 2007, 05:16:56 PM »
You got it Billy!
That is the part I need.
Anybody have one?
DAL777
« Reply #10 on: December 21, 2007, 09:19:40 PM »
I found the connector at a local chevy dealer.  $5.31   !!!!!!!!!
Hose and grommet discontinued in 1988.  Not available.
9T4Z
    • Gary's Camaro
« Reply #11 on: December 22, 2007, 03:16:16 AM »
Dal... oops
I have the L48 as well and assumed they were all the same.  Open element vents differently!
nice to see you found what you needed.  8)
Gary 9T4Z
DAL777
« Reply #12 on: January 01, 2008, 05:08:09 PM »
Yea, it is just a straight
piece of pipe.  I could not
believe my local chevy dealer had
them.  I bought three!  The hose
is not available so I got a radiator by pass
hose that works great.
