Author Topic: 1967 camaro 396 W/A.I.R. and T400 carburetor  (Read 17779 times)
Bernie
« on: November 30, 2007, 09:55:10 PM »
Can anybody help me with the right number? I am looking to find the right part number for a Calif. 67 camaro with a 396-A.I.R. and turbo 400.
Bernie
Ed Ernst
Re: 1967 camaro 396 W/A.I.R. and T400 carburetor
« Reply #1 on: December 02, 2007, 01:57:45 AM »
I'm not sure what part # you are asking for, but the engine suffix code stamped on the block pad would be MZ and the block casting # would be 3902406.
« Last Edit: December 02, 2007, 02:01:08 AM by Ed Ernst »
1967 SS/RS convertible - LA 12A built
Bernie
« Reply #2 on: December 02, 2007, 06:34:19 AM »
Ed I wasn't very plain in what i was asking for ( I am new at this) but anyway i was looking for the carb number for this engine I found the carb number but now i need to find out if it is the 1st, 2nd or 3rd type. The build date of my engine is 214.
Thanks for the help.
Bernie
« Reply #3 on: December 02, 2007, 04:30:12 PM »
The build date of my engine is 214. Bernie
Where did you see the "214"? The block casting date is just forward of the starter, near a freeze plug, and the engine assembly date and suffix is stamped on the front block pad.
67ModTop
« Reply #4 on: December 02, 2007, 05:13:05 PM »
Bernie,
I think all the smog Q- Jet carbs for a 396 Camaro have the same part number... Are you looking for a possible date tag?.. That's the round sucker on the side?
For a February 14 stamped motor, you might be looking for  A7 or maybe a B7 round tag.
Bernie
« Reply #5 on: December 02, 2007, 07:02:55 PM »
John & Tony
Hi i appreciate the feed back. The 214 came off of my POP which was TO214MZ. Rich came up with 3 sets of numbers for my car but also came up with 3 different types and now i am wondering what type i should  have on my car. I don't know if by type he means Rochester, Carter etc.
Bernie
« Reply #6 on: December 02, 2007, 10:56:57 PM »
Bernie
« Reply #7 on: December 03, 2007, 01:41:55 AM »
Kurt
Yes that is were my question comes from. The information is all there but Rich mentions 1st, 2nd & 3rd type after the ID number and that is what i am trying to find out what that means. For my set up there are 3 different ID numbers.
Bernie
« Reply #8 on: December 04, 2007, 02:46:07 PM »
1st version, 2nd verion, 3rd version.
Bernie
« Reply #9 on: December 04, 2007, 07:48:49 PM »
Kurt
How do I know which version is for my car with the engine build date of 2/14/7
Bernie
« Reply #10 on: December 06, 2007, 04:27:41 AM »
I'm not sure anyone knows the transition dates for that carb. :(  There is the chance that you will only find one of those three part #'s with the correct dates for your build date.
The engine date is irrelevant; the carb was put on in the assembly plant so the body build date is relevant.
Bernie
« Reply #11 on: December 06, 2007, 05:14:22 AM »
My car has an 04A build date
