Author Topic: Distributor Date  (Read 19818 times)
Camaro Billy
    • 1969 RS/SS
Distributor Date
« on: November 29, 2007, 04:56:52 PM »
Is a #1111489  -  8 H 21 (Aug 21st 1968 ) dated distributor too early for my 11D (4th week Nov. 1968 ) build car ?
I'm having allot of trouble finding a date correct one, and this is the closest I've found yet.
Thanks for any help.
Billy
1969 RS/SS 350/300 Rallye Green . Black Vinyl Top
tim69camaro
Re: Distributor Date
« Reply #1 on: November 30, 2007, 01:08:09 AM »
The date should be on or before the engine build date stamped on the pad. The closer the better. That far in advance seems to be outside the range prefered based on what I have seen. There are always exceptions, but if you don't have the known original those exceptions would not apply.
Tim Bailey
Jonesy
  • 1969 Camaro z28
« Reply #2 on: November 30, 2007, 02:05:07 AM »
My 11B has it's orig 1111488 distributor and it's dated 8 H 29, so it could be possible.
1969 Z28 Azure Turquoise
Jerry@CHP
« Reply #3 on: November 30, 2007, 03:28:21 AM »
Billy,
That date is fine for an early car.  These parts were made in big runs and from time to time there is a wide gap.  The famed Brandenburg survivor car in the beginning of my book is a mid Feb built car and it has a factory installed 8K30 1111480 distributor in it.
Jerry
« Reply #4 on: November 30, 2007, 07:32:32 AM »
I pulled one out of a L48 that was a December motor with an earlier than your distributor. Use it. :)
Camaro Billy
    • 1969 RS/SS
« Reply #5 on: November 30, 2007, 12:09:38 PM »
Thanks Guys, I going to see if I can snap it up.
Billy
« Reply #6 on: November 30, 2007, 07:07:22 PM »
Well Billy, did you buy it?  Are you "sugaree908"?     ;D
Camaro Billy
    • 1969 RS/SS
« Reply #7 on: November 30, 2007, 08:58:25 PM »
Paul,
That's Me ! Kinda tough without a picture, but I've been looking for one for a long time. Now I just have to have Jerry rebuild it for me.
Billy
DAL777
« Reply #8 on: November 30, 2007, 10:31:43 PM »
Billy,
I have an 11D car and it has a    8 J 18  which I believe is original.  The engine is  T 1106HB.
Jonesy
  • 1969 Camaro z28
« Reply #9 on: December 01, 2007, 10:04:27 PM »
Billy,
Thats about 19 days after my 11B car. they didnt use "I" for the month stamping on distributors
DAL777
« Reply #10 on: December 04, 2007, 01:59:48 AM »
So that makes mine about right?
« Reply #11 on: December 04, 2007, 02:54:25 AM »
And for a reasonable price too!     ;)
tinman75
  • 1968 ash gold rs-ss
« Reply #12 on: December 15, 2007, 12:07:00 PM »
I have a 68 L48 survivor 10D with 4 spd. trans. my distributor part # is 1111264 which is a correct 68 part # and the date is  7J5. I was wonderinging the same,  if it was to far apart but the part # matches the car perfect and the rest of the parts in the motor all are within 2 months.
« Reply #13 on: December 15, 2007, 04:06:24 PM »
That's September 5th - if it's prior to the stamped engine assembly date on the front pad, it should be OK.
tinman75
« Reply #14 on: December 15, 2007, 11:25:40 PM »
but it is a 10D 68 car and it is marked 7J5 and from what I am understanding the 7 stands for 67 or am I wrong?
