Author Topic: I have a 12 bolt question  (Read 9429 times)
docs692121
« on: November 14, 2007, 01:27:02 PM »
I have a multi-leaf 12 bolt posi rear end to sell but I need to know if the following casting number is for a Camaro or not; 3696341NF.
Re: I have a 12 bolt question
« Reply #1 on: November 14, 2007, 03:27:09 PM »
You sure about that number???? I think you may have some numbers transposed.
Maybe it's 3969341? If so, it's either a late 69 Camaro, or a 70-71 Nova axle. What's the axle code and the date?
docs692121
« Reply #2 on: November 14, 2007, 07:15:55 PM »
Yes, that is correct; I was recalling from memory but the number is 3969341NF.
Axle says  C BM 0624 G 2  {3:31 non-posi}; date code looks like B50.
Thanks for the reply.
« Reply #3 on: November 15, 2007, 12:31:00 AM »
If that's really the date (06-24, or June 24th), then it's "probably" for a 1970 Nova. The 1969 Camaro didn't start using the 3969341 axle until around the 08A (August, 1969) time frame.
However, I would bow to Kurt's input here if he has more info.
« Reply #4 on: November 15, 2007, 06:39:38 AM »
I concur, it's a 70 Nova axle. Will fit fine in a 67-9 Camaro. :)
docs692121
« Reply #5 on: November 16, 2007, 01:32:13 PM »
Thanks for the info guys;
I have had this unit for over 30 years...it currently has a GM high impact 4:88 posi unit with stock axles. The gears still have some of the yellow coating on them because it has not been used hardly any. It has never been welded or cut on. I am ttrying to track down the info I need before I sell it.
miket1
« Reply #6 on: November 30, 2007, 03:50:23 AM »
doc, thanks for calling me back, i will pickup as soon as possible, i'll call you ahead,  mike
69 Z28 Burgandy
