Author Topic: 69 388 block casting date vs build date  (Read 7987 times)
JKZ27
« on: November 14, 2007, 04:17:28 AM »
I recently found a complete 350 300 hp engine in a junked 69 full size station wagon, original to the car. The interesting thing I found is the 388 block was cast in September of 1968 but the engine was assembled in February of 1969. Seems like a long time difference to me. Unfortunately, the block is cracked so I'm wondering if its worth documenting before I throw it away.
John
John
68 RS Ash/Ivy Gold 327EFI M20
Re: 69 388 block casting date vs build date
« Reply #1 on: November 16, 2007, 04:19:55 AM »
I'd like a picture of the engine pad, if possible. :)
Thanks!
tar6569
« Reply #2 on: November 16, 2007, 04:30:17 PM »
I would like one too. :)
Would it be possible to get a picture of the trim tag on the firewall before it is scrapped?
Warren
Warren
1964-1970 fullsize Chevrolet research
JKZ27
« Reply #3 on: November 20, 2007, 03:38:20 AM »
Unfortunately, I left the car with its trim tag at the junk yard. I only took the complete engine. I could go back and see if it is still there, I'm always looking for reasons to go to the junk yard.
I'll try to get some pics of the engine pad out asap. Thanks for the interest.
John
John
Jerry@CHP
« Reply #4 on: November 20, 2007, 03:51:11 PM »
John,
Include me in the photos if possible.  Might be able to use some of this data in the new 4th edition Camaro book that I'm working on now.  Mail to z28camaroman@juno.com.
Jerry, CHP
fireZ
« Reply #5 on: November 20, 2007, 04:17:26 PM »
I can believe the time span between casting and assembly. My Grandfather always said things did not follow an inventory program back in the day with parts arriving and being used in sequence of arrival. I should have listened to him more when he was around.
1968 Z28 LA Built
LIC # RPO Z28
JKZ27
« Reply #6 on: December 11, 2007, 07:43:28 PM »
The numbers appear as: Casting date I 28 8, Assembly T02I2HN, VIN 192065800. Heads and intake both cast B 4 9.
John
John
« Reply #7 on: December 13, 2007, 12:21:05 AM »
That casting date (September 28th) is pretty early for a February-built high-volume engine; if you look closer, you'll probably find that it's L 28 8, December 28th.
