Author Topic: Muncie M-21 Help  (Read 9610 times)
mcp
Muncie M-21 Help
« on: November 09, 2007, 10:13:57 PM »
During hard de-accelleration in fourth gear @high RPM and let off the gas, my transmission jumps out of gear.  Fourth gear and only fourth gear.  Does anyone else have the same sympton and does anyone know the fix?
Marty
Re: Muncie M-21 Help
« Reply #1 on: November 10, 2007, 02:39:30 AM »
My trans does that too. I've been told the synchros are bad.
Martin Foltz
CRG Member
68 Van Nuys Camaro
« Reply #2 on: November 10, 2007, 07:24:20 AM »
From my dark past I remember that as a bad synchro.
fireZ
« Reply #3 on: November 10, 2007, 01:15:30 PM »
I had that happen and it was the syncros
1968 Z28 LA Built
LIC # RPO Z28
x77-69z28
« Reply #4 on: November 12, 2007, 07:55:16 PM »
yup. the brass rings in the three four synchro. it is an easy fix. jerry will do it for you.
Jerry@CHP
« Reply #5 on: November 13, 2007, 01:51:22 PM »
It's not the synchros, it's the 3-4 slider that causes that.  The brass rings slow the gear down so it can go into the next gear.  When a trans grinds when going into gear, that is the brass rings going bad.
Jerry
fireZ
« Reply #6 on: November 13, 2007, 05:26:00 PM »
Thanks for the info. Jerry,I was told it was my syncros also and it did not fix the problem.
1968 Z28 LA Built
LIC # RPO Z28
