Author Topic: Trans cooler  (Read 11504 times)
Bjv69ss
Trans cooler
« on: October 27, 2007, 11:15:38 PM »
I have a 69 with a tweeked 350.  Nothing major but the mods require a 2400 stall converter.  The Converter and trans kit comes from B&M.  They suggest a trans cooler.  Should I be running the cooler through the radiator tank and into the aux cooler or skip the radiator? ???
Thanks for the input... Joe
1969 Fathom Green
SS 350 Coupe
71 Impala Sport Coupe
hotrod68
  • almost finished
Re: Trans cooler
« Reply #1 on: October 31, 2007, 03:06:42 AM »
For my 2 cents, if you use a big enough cooler, you can skip the plumbing to the radiator--it only complicates the installation and the engine will run a tad cooler without the transmission fluid flowing through the radiator tank. I have a 3500 converter in my '68, which is very loose and creates a lot of heat. I used a heavy-duty 7-tube aftermarket RV cooler and it works fine on my car. But by all means, use an auxiliary cooler! A 2400 converter isn't that loose, but on a hot day in traffic you'll be glad you did. Heat kills an automatic transmission. Mount the cooler in front of the radiator in the airstream. Good luck!
Bjv69ss
Re: Trans cooler
« Reply #2 on: November 02, 2007, 10:21:38 AM »
Thanks for the info.  Makes sence to run a big cooler.  Joe
1969 Fathom Green
SS 350 Coupe
Bjv69ss
Re: Trans cooler
« Reply #3 on: November 23, 2007, 03:18:45 PM »
I've been looking at the trans cooler kits and really don't care for the rubber hose and clamp connections.  Is there one that has threaded, plumbed connections?
1969 Fathom Green
SS 350 Coupe
hotrod68
  • almost finished
Re: Trans cooler
« Reply #4 on: November 24, 2007, 03:34:53 AM »
B&M, Flex-a-lite and TCI all make them. Most of them have -6AN fittings. You need to be pretty handy with a tubing bender and flaring tool, though. It's a time-consuming job to hand-fit cooler lines, but well worth it if you have the patience. Good luck!
Bjv69ss
Re: Trans cooler
« Reply #5 on: November 24, 2007, 01:29:01 PM »
Looks like a trip to the speed shop.  The catalogs don't seem to have the plumbed type.  I would always worry about the rubber lines.
Joe
1969 Fathom Green
SS 350 Coupe
hotrod68
  • almost finished
Re: Trans cooler
« Reply #6 on: November 25, 2007, 03:46:10 AM »
Jeg's and Summit have them in their catalogs, Joe. And they're great folks to deal with. Have fun!
Bjv69ss
Re: Trans cooler
« Reply #7 on: November 25, 2007, 02:26:31 PM »
I'll have to look again.  I noticed the kits with the hose and clamps only.  Maybe I should read more and look at the pictures less...
1969 Fathom Green
SS 350 Coupe
