Author Topic: 1968 ss rs 396 325 hp fan  (Read 18202 times)
earl
« on: January 09, 2006, 03:23:13 AM »
can anyone tell me what the correct rad. fan looks like  or have pic's for 1968 ss rs 396 325 hp. no ac and what length fan spacer
thanks
« Last Edit: January 09, 2006, 03:35:37 AM by earl »
68rsssrag
Re: 1968 ss rs 396 325 hp fan
« Reply #1 on: January 09, 2006, 05:53:03 AM »
Earl
Look at the CRG Reports section on the maun webpage. There is a ful report with all the info you are asking.
Cheers
Arno
« Reply #2 on: January 09, 2006, 07:02:12 AM »
Earl,
Please don't post the same question in multiple forums, once is fine. :)  I deleted the other two posts.
Thanks!
earl
« Reply #3 on: January 09, 2006, 07:02:33 PM »
Earl,
Thanks!
sorry about that i did not know were to post
earl
« Reply #4 on: January 09, 2006, 07:11:43 PM »
Earl
Cheers
Arno
thanks thats what i needed
Pex68
« Reply #5 on: January 09, 2006, 11:22:14 PM »
Got a question on this one, how many people actually have the 4 blade fixed fan on their 396/325 and how many have a clutch fan?  Would be interested in the year and what options also.  Mine came with the fixed 4 blade fan and I replaced it with the clutch fan because the fixed fan had a stamp on it that read FoMoCo and I took that as Ford Motor Company and obvoiusly not right.  anyone else seen this???  Found the CRG report a while ago and have been questioning it ever since.
My car is a 68/396-325/M20/no AC.
Chris P
earl
« Reply #6 on: January 10, 2006, 03:09:57 AM »
mine is a 4 blade but i can not find any#s
« Reply #7 on: January 10, 2006, 09:42:24 AM »
Most L35 cars got the 4 blader.
I've looked at enough docs to say that. :)
earl
« Reply #8 on: January 25, 2006, 05:04:21 AM »
do you have some pics of the 4 blade fan
Steve68
« Reply #9 on: January 26, 2006, 01:35:57 AM »
Earl
Go to the CRG Reports button in the upper left corner and click on it.  Then click on the "cooling systems" report and go to the bottom of the page and you will find a picture of the 4 blade fan.
tim68rsss
« Reply #10 on: February 03, 2006, 04:22:01 PM »
Interesting Fact: My 68 RSSS 396/325 Auto (build date 11/67) with AC came with a four blade fan unless the original owner switched it out. I know the report says that it should be a five blade fan with clutch. I'm 99.9% sure my setup is original though. Car only has 52000 miles and I have all of the orignal engine components (water pump, alternator, and starter) which I had rebuilt. The fan spacer was still attached to the water pump when I bought the car. Car also has the 4-core Harrison radiator.
