Author Topic: 69 tachometer help  (Read 7833 times)
zackan
69 tachometer help
« on: October 19, 2007, 01:30:54 AM »
The tach in my car has recently started to "jump" at idle. I mean that it  quickly fluctuates 500 rpms up and down without the engine speed changing. Once the idle speed is increased, the  jumping stops and it appears to read accurately. ANy idea what could cause this.
melav8r
Re: 69 tachometer help
« Reply #1 on: December 16, 2007, 07:23:39 AM »
I experienced the exact problem, sounds like you need a tach filter, are you running electronic ignition? Try this easy and inexpensive fix, worked great for me and I installed it in the harness near the drivers kick panel out of sight.
http://www.camaros.net/techref/electrical/tachfilter/
melav8r
« Reply #2 on: January 01, 2008, 07:41:00 PM »
Hey Zackan, did you fix or find the problem with your tach?
just wondering.
