Author Topic: Legit or not pad stamp ??  (Read 15267 times)
Rod67
« on: October 16, 2007, 03:58:38 PM »
Does this assemly date & partial vin look legit, and if it does, anybody ever hear of the last number of the vin missing the pad ???
thanks
Rod67
Re: Legit or not pad stamp ??
« Reply #1 on: October 16, 2007, 04:08:23 PM »
Sorry the picture is so small, hope this size picture is easier to see.
Rod67
« Reply #2 on: October 16, 2007, 04:34:09 PM »
and again
« Reply #3 on: October 16, 2007, 05:02:30 PM »
Looks like this pad, probably cause it's the same one.  :)
This pic is from last month, from ebay.
Rod67
« Reply #4 on: October 16, 2007, 05:11:16 PM »
Sure i got this block off ebay, but is the stamp legit??
« Reply #5 on: October 16, 2007, 06:49:45 PM »
Appears to be OK.
Rod67
« Reply #6 on: October 17, 2007, 01:56:19 PM »
Thats good news, thanks kurt. The reason i got this block off ebay was because of the assemly date. My original engine is long gone and the 396 that was in my car is from a 1966 impala. I do have the POP for my car and the assemly date for my original engine is T0617MW, 11 days after the assemly date on the block i got from ebay, probably as close as i will ever get to my original engine.
thanks
« Reply #7 on: October 17, 2007, 06:50:50 PM »
Rod,
No problem.
btw, if you have problems with your ID, just email one of us and we can fix it. No need to get a new ID. :)
Rod67
« Reply #8 on: October 18, 2007, 02:20:43 PM »
Kurt, I'm not getting a new ID & wasn't aware of any problems with the ID i have. Plaese let me know if there are any problems.
thanks
Rod
« Reply #9 on: October 18, 2007, 03:41:01 PM »
See http://www.camaros.org/forum/index.php?topic=30.150
It sure appeared like the post by rod67ss is by you.
Yes I did... but it was years ago. You should find the posts under doing a T56 swap into a '67 that I did back in '98. Not sure of the date of posting - but it was under rod67. I couldn't remember my password & my Email has changed so I just registered again under rod67ss.
tar6569
« Reply #10 on: October 19, 2007, 04:22:13 PM »
Hey Rod, can you post the full engine pad numbers from the 396 in your car (that from a 66 impala), so i can add the info to my fullsize list?
Thanks, Warren
Warren
1964-1970 fullsize Chevrolet research
Rod67
« Reply #11 on: October 19, 2007, 06:25:10 PM »
Kurt, I have had the same ID, Rod67 since Oct. 2005 when i joined, its the only ID i have had. Rod 67ss is someone else.
tar6569, I will post those numbers for you as soon as i can. ( @ work right now )
thanks
Rod
« Reply #12 on: October 19, 2007, 07:50:44 PM »
Thanks! You can see how I was confused since he says he was rod67!
Rod67
« Reply #13 on: October 19, 2007, 08:40:46 PM »
Kurt,  I was looking back and i must have joined around March or April of 2005. My mistake on the Oct. date. That must be when the new formatt started. Anyway i was Rod67 in the old & new forums.  Thanks for all your help.
tar6569,  here are your numbers on the impala 396.  Pad : T05I8IVR and they are I's not 1's.  Partial vin : 6S260489. Casting date on block : D 22 6. Heads : 3872702 with casting dates of E 12 6 both heads are the same. Number by the flange at the back of the block : 3855961. Hope this helps.
thanks
Rod
