Author Topic: 1967 master cylinder and brake booster  (Read 4891 times)
onebad34
« on: October 08, 2007, 08:47:26 PM »
What should be the correct casting # and suffix code stamping on the front for a 1967 SS camaro with power disc brakes.  Also on an original delco moraine brake booster are the O's in delco moraine split into two half moons or are they a complete O?  Any help would be appreciated.
Thanks.
67 kemie ss
Re: 1967 master cylinder and brake booster
« Reply #1 on: November 03, 2007, 05:54:52 AM »
The correct cast # is 5460346 and the suffix code is WT on the front pad.  I have been assured by many that all of these masters had bleeders - although the AIM for 67 shows one without.  Some of the MCs may also have had a Julian code stamped by the front brake line.
Don't know the answer to your second question, but on the 67 brake boosters for disc brakes the correct stamp number is 8515 and there was no Delco Moraine stamp on the face of the booster.  If your booster has such a stamp then it is not correct for a 67.
