Author Topic: Installing factory dash clock for 69 Camaro advice needed  (Read 11029 times)
sdkar
« on: September 26, 2007, 02:53:52 PM »
I would like to add a factory dash clock to my 69 Camaro.  What is the procedure in doing this to a non-clock car?  I am sure I have to cut the panel.  Any advice on anyone who has done this?  Anything I need to know to avoid ruining my dash bezel?
Re: Installing factory dash clock for 69 Camaro advice needed
« Reply #1 on: September 26, 2007, 03:10:44 PM »
Here's a template for the cutout I found at www.camaros.net .
Jonesy
  • 1969 Camaro z28
« Reply #2 on: September 26, 2007, 06:39:40 PM »
There are also some plastic tabs on the dash part that need 2 special push on studs to mount the clock from behind.
1969 Z28 Azure Turquoise
mrdetails
« Reply #3 on: September 26, 2007, 07:49:36 PM »
There are also 2 metal clips (with hole for screw) that clip on the top edge of the dash that hold the lens on at the top. (I have a couple of these) I also have a couple of the stud  tabs, although most of the ones I've seen have a push on clip that takes a screw to hold clock to dash. I usually make the cutout with a hot knife but a coping saw would work, go slow.
Sam
sdkar
« Reply #4 on: October 23, 2007, 12:28:25 AM »
Does anyone have a pic of the dash bezel for a console clock but with the clock removed.  I have the template above but seeing an actual bezel with the cutout will help me from cutting mine up incorrectly.  Post pic here or email pic to sdkar@bellsouth.net
eke
« Reply #5 on: November 04, 2007, 08:34:38 PM »
I will try and take the needed pictures in a day or so. What all do you want pictures of? I have my complete dash panel out so I can get whatever you need.
mark x22
« Reply #6 on: November 04, 2007, 09:52:45 PM »
