Author Topic: Missing Trim Tag  (Read 22878 times)
Flowjoe
Missing Trim Tag
« on: September 12, 2007, 06:26:13 PM »
I have a '69 convertible VIN 124679N679379 that has a POP but is missing it's trim tag.  KurtS has seen this car at my house.  It would appear to be a red on red std car with white power top..this is all from the physical evidence.  I believe Kurt agreed with this assesment.  The body color and interior color are not called out on the POP.  I would like to replace the trim tag and would like comments on the best way to have it reproduced.  The POP reads as follows:
                           124679N679379   B
T0827DD               BA0828G             9
B0M11                   13
I decode as follows:
B = Bay City 2bbl
T0827DD = Aug. 27 307 w/TH350
BA0828G  = Aug 28 2.56:1 open
9 = September build
BOM11 = ?? August 11th
1= N40 power steering
3 = Radio
Based on the VIN I put the build date as 09A (on or around Wednesday September 3rd)
It has some but not all of the bright trim (1/4 louvres, front wheel well trim) ...is it X-44 or X-11?
the 307 is no longer with the car (it had a wasted December '68 date 307 instead), the TH350 and rear axle appear to be original.
thanks in advance
Flowjoe
Re: Missing Trim Tag
« Reply #1 on: September 12, 2007, 11:33:40 PM »
Let me put this another way...here is how I would configure the "new" trim tag:
ST 69 12467      NOR? ? ? ? ? ?  BDY
TR 718               52 A           PNT
09A                                X-11
What should i put into the body identification number area?  Does anyone else see a problem with having a new tag made like this?
« Reply #2 on: September 13, 2007, 06:30:13 AM »
I remember seeing a bunch of cars at your place. And a bunch of lizards. :)
So this one is the next project?
B - Cleveland THM350
0 - 1970 (it was already the new model year)
M11 - August 11
Flowjoe
« Reply #3 on: September 13, 2007, 01:55:17 PM »
M11 - August 11
This one was sitting way out in the back under a tarp.  It's sort of the next project...I bought it with my best friend with the intention of converting it to a BBC w/ 4 speed - going the hot rod route.  So we got started on it and then decided that we didn't want to keep it and that we should sell it (other things to do wiht our time and money).  A car with no trim tag always seems to cause suspicion and lower the selling price...so I wanted to put one back on but I want it to be as accurate as possible.
So what do you think on the repro trim tag?  Is there one vendor better than another?  what should I do about the body idetnification number?  jsut pull a number out of thin air?   Is there a logical pattern?  I'm not trying to turn this into something it is not - I want it to look legit and represent the actual car.
drdave69
« Reply #4 on: September 13, 2007, 05:21:02 PM »
Why not put XXXXXX for the body number on the repro trim tag along with the other data you already stated? And, before you attach it stamp "REPRO" on the tag so that there will never be a question about it being a replacement tag.
Flowjoe
« Reply #5 on: September 13, 2007, 08:01:53 PM »
that would be worse than having no tag.  It's not like I'm trying to create some exotic car here...I'm trying to give it it's identity and life back (this poor car was full of 22 long rounds both spent and live...found them in all sorts of places, had headers and remote dual oil filter, crazy wiring and a Z/28 badge on the tail panel).
I was hoping for some input from the CRG as to what acceptable practies were for replacing trim tags...I'm fairly certain of most of my info (and at the time Kurt agreed that it was a Red on Red car)....so I was looking opinions as to which approach would be more legit from a group of people that spend a lot of time looking at theses sorts of things.  I also figure that if I replace the trim taag "correctly" then it is les likely to be bought by someone and have a tag added that declares it to be an X-22 car with 4 speed and a bazillin options.  If there is a concern that the information I seek may help counterfeiters then I would be happy to take my answer via Email or PM.  Jus let me know to whom I should write.
So I will put you in the camp of leaving what I don't know essentially blank and labelling it as a reproduction...there's one data point...any others?
Jonesy
  • 1969 Camaro z28
« Reply #6 on: September 14, 2007, 01:32:08 AM »
My guess is that you arent going to get an endorsement or body number from anyone in the CRG. I dont think Dave was that far out of line.
Is it really that important as to what body number you put on it if it is a repop tag??
1969 Z28 Azure Turquoise
Flowjoe
« Reply #7 on: September 14, 2007, 06:44:15 AM »
I hear your comments but I guess I need to be more direct about my question.
Everytime a car turns up with a reproduction tag it gets ripped to shreds for what is wrong with it.  I want to avoid that by getting input before hand on what should be there - or shouldn't.
Everytime a car turns up without it's trim tag it is instantly suspect and is picked apart because of it.  I want to avoid that by getting input before hand so I can decide if it is better to leave it as is (no trim tag) or get a repro.
My buddy and I  have decided not to keep the car - it took us over three years of holding the car and futzing around with it  to get to that point (and a lot of elbow grease not to mention a little but of cash)...I'd like to get the best price I can for the car - is it better to leave the tag off?  Or better to get the reproduction?
The people at the CRG (both actual members and the forum crew) are very particular...something I value.  I consider it the definitive 1st gen info site.  I want to know how members of this community would prefer  to see this sort of thing dealt with...I have Dave's input.
I have tried to be up front about the car...I have given away the VIN and POP info right here.  I could have repopped the tag with x-11 stamped on it, stuffed one of my extra 12 bolts in it, put on an SS hood and done the other things to clone it but not call it a clone...I could have gone the whole x-22 route.  Instead I'd like to do right by the car and the hobby.
It is a base V-8 Convertible missing its trim tag and original engine but with its  POP and orignal tranny and rear axle.  Should it get a repro tirm tag or not?  If it does get one how should it read?
For the record, I think that X's where the body id should be would look awful...I would stick something like 123456 or it's birthday (091969) in there if a reasonable sequence could not be established.  I also think that hand stamping "REPRO" on the tag would look equally poor...and besides, it is not like I'm creating a fantasy car here.  The proposed replacement tag wouldn't claim anything that I can't support.
drdave69
« Reply #8 on: September 14, 2007, 11:35:11 AM »
The reason that I suggested XXXXXX for the body number is to leave no doubt that it is a replacement tag. Not all buyers in the distant future will know what a replacement tag looks like if it were to have 6 numeric digits for the body number, unless they are blatantly obvious (like 999999). After all, it is still going to be a repro tag so why not make it very easy to spot even by someone like me that can't really distinguish a repro from a real one.
Flowjoe
« Reply #9 on: September 14, 2007, 11:25:08 PM »
Fairly reasoned.
I find it astounding no one other than Dave and Jonsey have opinions on this matter.  In a hobby that spends a lot of time discussing things like  the correct level of gloss on retored chassis components it seems odd that there is not a "preferred" method of "restoring" a missing trim tag.
Everyone up here is very free with their knowledge and time to help forum members restore a car "correctly"...I would have thought that this would be one more aspect of trying to right what has gone wrong with a car since it rolled off the assembly line 38+ years ago.
So I guess the question I asked in my last post remains:  Should I replace the trim tag or not?  If I do, how should it read?
Jonesy
  • 1969 Camaro z28
« Reply #10 on: September 15, 2007, 01:23:38 AM »
I think this is a taboo area for the purists. Many of the guys who hang here are that, IMO. I think that is why the response rate is low.
I would think most would not want to see a repop tag on there.
I think the repop tags that get ripped to shreds are because they are repops and can be pointed out.
I am not sure what's better, leave it tagless or put a repop tag. IMO, a repop tag raises way more questions than you having no tag and POP.
Flowjoe
« Reply #11 on: September 15, 2007, 04:35:26 AM »
You may be right about the Taboo factor...you are definitiely right about the purists...of course that is one of the reasons that I come here.  that is also the reason that I came here and asked about the trim tag...I figured that I would get the dirt on the best way to handle it.  Taboo or not, you'd thnk that they would have an opinion that they would be willing to sahre...a simple yes or no would even suffice.
  You could well be on to something here..but again, you'd think they 'd have an opinion and historically they are pretty free with their opinions
We'll never know unless someone chimes in.  If the overwhelming opinion were not to put  a repro tag ont eh car then I would probablly leave it off..that is why I asked the question in the first place.
That would imply that there are tags that cannot be spotted...I have the feeling from opinions expressed here in the past that a knowledgable person can always spot a repro tag.  I am not such a person.  My observation is that even the "good" repros get cut to shreds here.  Which, of course, supprots your position that most here would not want to see a repro tag.
And that is a reasonable position to take although I don't necessarily agree (right now, the jury is still out for me).  Can you enumerate your reasons for feeling that it raises more questions?  In particular think about my situation.  this is the first car I have had that does not have a trim tag (excluding one or two parts cars that were destined to be cut up) so this is new territory for me.  For the life of me I cannot understand why , taboo or not, no one will simply say don't or do put a repro tag on the car...It seems that some sort of standard for this would bennefit the hobby  - mine is not the only car out there that has lost it's tag....maybe that Z/28 emblem on the tail pan was no abberation, maybe it was the long lost 1 of 1 '69 Z/28 convertible ;D
gflac
« Reply #12 on: September 15, 2007, 03:17:08 PM »
Im not sure how Id handle the problem myself. I dont think there is anything "wrong" with adding a Trim Tag that is as accurate as possible.  I would argue that it is part of the restoration of the car.  There is no attempt to falsify information on your part especially having the POP in hand.  I sometimes think the members of this site are reluctant to utter an opinion so that they cant be held to it later.  In any event, I think a discussion of this topic would be worthwhile in order to come to some kind of consensus about a good way to proceed when a Trim Tag is missing.
tom
    • Discount Internet Services
« Reply #13 on: September 15, 2007, 05:49:54 PM »
If you need to replace the tag, I would suggest that a photo of the repro tag be provided to the forum members to reference in the future. If you put it on e-bay, state that the tag is a repro, and the reason in your ad. That might reduce the shredding of it on the forum. I would try not to get a perfect copy, so that in the future it will not pass muster if someone does try to pass it off. At the present I don't see the 307/auto as a highly sought after, rare and high priced car, but 30 years ago nobody expected to see any 6 figure priced Camaros.
In the end, you will do what you will do.
Good luck,
Tom
69 X11 Z21 L14 glide
o
« Reply #14 on: September 15, 2007, 08:24:54 PM »
I remember that car. It did have that lizard on it that wouldn't move. :)
I venture that it's probably not worth putting the tag on it. There's a % of people that know Camaros that would be interested in the car and the tag info. They would know the tag was missing. But a large % would just want a ragtop and they don't know much about Camaros (could have been a Chevelle or something else). They wouldn't care about the tag and would just build the car to what they want.
You'd hate to put in on and then have someone smooth the firewall......
