Author Topic: U35 console mounted clock  (Read 9670 times)
Claus
    • Yutivo
« on: September 07, 2007, 05:51:04 AM »
Does the "guts" from the gauge pod clock in a 67 fit the single U35 clock?
Claus
    • Yutivo
Re: U35 console mounted clock
« Reply #1 on: September 09, 2007, 11:05:59 PM »
Is the U35 "electric clock" cup the same for floor mounted and console mounted?
I found a clock that seller says is a floor mounted clock and as you can see below I "desperately" need to replace the "thing" on my Yutivo Camaro console.
« Reply #2 on: September 10, 2007, 12:12:02 AM »
Claus, the clocks are different between the floor mounted and the console gauge version. Also different between 67 and 68. Here's the breakdown:
1967 floor mounted (without gauges) - 987035
1967 floor mounted (with gauges) - 3901613
1968 floor mounted (without gauges) - 3921410
That being said, I have no idea if any of these interchange into the "non-gauge" clock pod you have.
Claus
    • Yutivo
« Reply #3 on: September 10, 2007, 01:48:03 AM »
Thanks a lot Ed, I have asked seller for a part number.
I am sure its a floor mounted clock without gauges, see picture.
67 or 68?
« Reply #4 on: September 10, 2007, 02:49:57 AM »
That looks to be a 68 floor mounted clock (without gauges). The 67 didn't have the center circle.
Claus
    • Yutivo
« Reply #5 on: September 10, 2007, 03:12:27 AM »
Thanks again Ed.
I might settle for this 68 clock, its hard to find them.
Claus
    • Yutivo
« Reply #6 on: September 10, 2007, 04:11:34 AM »
So I take it this is a 67 clock:
« Reply #7 on: September 10, 2007, 01:57:20 PM »
Correct, but I'm not sure if that's the guage clock or the non-gauge.
Claus
    • Yutivo
« Reply #8 on: September 10, 2007, 02:03:24 PM »
I am "suspecting" its a gauge clock, wonder if it will fit in the U35 cup.
