Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Decoding/Numbers
AXEL #'S
« previous
next »
Print
Pages: [
1
Author
Topic: AXEL #'S (Read 7864 times)
Bjv69ss
Member
AXEL #'S
on:
August 06, 2007, 12:14:45 AM »
I just pulled the rear end out of my 69 SS for overhaul. I have the axel code but not sure of several letters.
..C & E. Here is how it appears on the axel.
C BR 1017G1 I'd appreciate the input. Thanks
E
Tweet
Logged
1969 Fathom Green
SS 350 Coupe
71 Impala Sport Coupe
Hero Member
Re: AXEL #'S
Reply #1 on:
August 06, 2007, 12:33:28 AM »
CBR is either a 3.07 Posi from a very late 1969 Camaro, or a 3.07 Posi from a very early 1970 Nova.
This one was assembled on October 17th at the Detroit Gear and Axle plant, 1st shift.
What's the date on your Trim Tag?
Logged
Bjv69ss
Member
Re: AXEL #'S
Reply #2 on:
August 06, 2007, 12:46:16 AM »
Ed,
Hope I have the right # 150116
What's the "E" mean? Any Idea
Joe
Logged
1969 Fathom Green
SS 350 Coupe
Hero Member
Re: AXEL #'S
Reply #3 on:
August 06, 2007, 01:01:35 AM »
Joe,
Check out
THIS ARTICLE
regarding the Trim Tag for the date. You should see a number then a letter. In your case, you should see something like 10A, 10B, etc... The 150116 you posted is probably the Body Number.
The "E" stands for Eaton Posi, one of the manufacturers of the posi carrier Chevrolet used.
Logged
Bjv69ss
Member
Re: AXEL #'S
Reply #4 on:
August 06, 2007, 08:11:41 PM »
Ed,
The tag reads 10E
Logged
1969 Fathom Green
SS 350 Coupe
CRG Coordinator
Re: AXEL #'S
Reply #5 on:
August 07, 2007, 03:22:50 AM »
The axle is original to your car.
Logged
Bjv69ss
Member
Re: AXEL #'S
Reply #6 on:
August 07, 2007, 10:19:58 AM »
COOL
Logged
1969 Fathom Green
SS 350 Coupe
Bjv69ss
Member
Re: AXEL #'S
Reply #7 on:
August 12, 2007, 01:34:39 AM »
I got the cover off and counted the teeth on the gears looks like it was changed from a 3:07 to a 3:50 ratio. I have 42 teeth on the ring and 12 on the pinion. I divided and came up with a 3:50 ratio. Did I do it right?
Logged
1969 Fathom Green
SS 350 Coupe
CRG Member
Re: AXEL #'S
Reply #8 on:
August 12, 2007, 07:01:04 PM »
[/quote]
The tooth count for both the ring gear and pinion gear is stamped on the O.D. of the ring gear on GM gears, along with the date they were made.
Logged
Print
Pages: [
1
« previous
next »
Decoding/Numbers
AXEL #'S
