Author Topic: T3 vs PowerBeam Headlamps in 67-69's  (Read 29909 times)
9T4Z
    • Gary's Camaro
« on: August 04, 2007, 09:29:26 PM »
OK with T3's becoming very rare (and the repop correct only for 55-57 Chevy's).....
Are the PowerBeam headlamps an acceptable bulb for "show judged competitions"?
These bulbs were available in 70's as GM replacements for the T3 and was wondering if the "Judges" were becoming more flexible here...
thanks if anyone knows...
Gary 9T4Z
94Z rag blower 491 rwhp (now 505!)
69 Pace Car, 70RS,91Z,91RS
sd1968z28
Re: T3 vs PowerBeam Headlamps in 67-69's
« Reply #1 on: August 04, 2007, 11:23:00 PM »
i had the original t3 lamps in my 68z, worked fine so i thought i drove it to auto mania car show one nite and on the way home they both burned out.  moral of the story do not trust old lamps,  use them at a day time car show and put in some modern lamps.
lakeholme
  • 68-12D L30/M35
« Reply #2 on: August 05, 2007, 01:20:34 PM »
The entire classic car world is still debating headlamps and radial tires...
It really would be great if Camaro had the kind of judging specs that Vette owners do, but looks like that will never happen.
« Last Edit: August 05, 2007, 01:40:20 PM by lakeholme »
« Reply #3 on: August 05, 2007, 03:08:24 PM »
In NCRS Corvette judging, T-3 headlamps are allocated a total of 12 originality points (3 per lamp); Service replacement GM/Guide headlamps get a 70% deduction, any other brand of replacements get a full 100% deduction. However, reproduction T-3's that vary in appearance from the originals only by the DOT marking only get a 25% deduction (3 points) for a full set of 4.
lakeholme
  • 68-12D L30/M35
« Reply #4 on: August 05, 2007, 10:39:09 PM »
BTW, I suppose I should have added that the debate is originality versus safety.  Afew years ago, it was hard to even get it discussed.  Now, at least it is discussed...
Farm Boy
« Reply #5 on: August 07, 2007, 03:56:38 PM »
I run the original 40+ year old T-3’s that came in my car when it was new. I often drive at night and the light they cast is every bit as bright as my “modern” vehicles.
I give the original Guide T-3 headlights the highest of ratings for lighting up the dark road and extremely long life.
9T4Z
    • Gary's Camaro
« Reply #6 on: August 07, 2007, 06:41:17 PM »
Sorry can't agree with the first statement.... perhaps its your definition of "modern"....      ;)
Long lasting... well 40 years can't be argued with...
Gary 9T4Z
« Reply #7 on: August 08, 2007, 02:57:41 PM »
They'll last even longer if you clean and apply epoxy around where each terminal emerges from the glass as a secondary seal; that's where the original seal deteriorates, allowing air to leak into the bulb, resulting in blackening first, then filament failure. :)
Ron C.
« Reply #8 on: August 17, 2007, 09:03:25 PM »
I noticed the 70 chevelles have the T-3 lamps and my 71 chevelle has the power beam lamps and also in a pic on the 71 chevelle dealer brochour the SS chevelle has them in the pic,so I would guess that 1971 was the first year for the power beams.
67L48
« Reply #9 on: August 20, 2007, 02:15:15 PM »
I can.  Original headlights in my 67 and they perform as well (performance = illuminate the road) as my 2005 F150, my 2001 Chrysler minivan, my old 1996 Ford Ranger, etc.
67L48
1967 Camaro SS 350
PG, factory air, console, fold down rear seat, PS, PB, butternut yellow, #s matching, original manual/warranty/POP, <60K miles
Northeast Iowa
9T4Z
    • Gary's Camaro
« Reply #10 on: August 20, 2007, 11:07:35 PM »
Well that explains it..... I've only ever owned GM's    :)
Gary 9T4Z
Jerry@CHP
« Reply #11 on: August 20, 2007, 11:58:01 PM »
Factory installed Power beams have been found in late production 1969 Camaros and are acceptable.  The 05A survivor that I owned had them.  We also went through this many years ago judging at the International Camaro Club Camaro Nationals.  Would not install them in anything earlier than this (May 1969) if you want full judging credit.
Jerry
jeff68
« Reply #12 on: August 22, 2007, 01:30:07 PM »
FYI - I found NOS T-3 headlights from a place called Dated Components in Kempton, PA (610-756-6453) a while back.  He may still have some.  I tested them, but after seeing the light output I have no intention of actually using them for night driving.
Also, Lectric Limited claims that they will have the 'correct' T-3 reproduction headlights available in September.  If these are good reproductions, I may just end up selling my NOS lights and get these:
http://www.lectriclimited.com/mainpage.htm
« Last Edit: August 22, 2007, 01:45:26 PM by jeff68 »
9T4Z
    • Gary's Camaro
« Reply #13 on: August 22, 2007, 05:43:13 PM »
Jerry my Camaro is 05A so now at least I have a choice....
Jeff thanks for the information... will keep track of it.
ps sell the NOS now before those repo's come out... they look good and if so the NOS prices will drop off   :o
« Last Edit: August 23, 2007, 12:13:46 AM by 9T4Z »
Gary 9T4Z
rat pack
« Reply #14 on: August 25, 2007, 03:25:58 PM »
Ron, actually the 70 Monte Carlo was the first Chevrolet passenger car to get the Power Beams. My theory has been since Chevrolet switched to the Power Beams for the 70 model year, some late 69 Camaros would have them instead of the T3's. Jerry's answer surprised me about May built 69's possibly having the Power Beams.  I have found that just about all 1970 model Chevrolet cars that had the 2 headlamp system used the Power Beams,  there have been a few exceptions where T3's were found in early cars. The 70 Chevelle still used the T3's as did most of the GM carlines that had the same 4 headlamp system. Last week I looked at a low mile unrestored 70 Corvette and 3 of its lamps were T3's, the other was a Power Beam. The owner could not say whether the light was changed or not. I am not sure what the norm was for Corvettes though. JohnZ can shed some light on that one. So your 71 Chevelle will have the Power Beams..............RatPack...........................
BTW, John, I have epoxied every good T3 I have now so as not to get any air leakage into them. Thanks for the tip!............................
