Author Topic: Oval floor/trunk pan plug sealent.  (Read 15514 times)
bbd564
« on: July 24, 2007, 01:11:40 PM »
Does anyone have a recommendation for a product that looks like the original cream colored sealent used to put the oval trunk/floor pans is place?
Thank you.
Re: Oval floor/trunk pan plug sealent.
« Reply #1 on: July 25, 2007, 01:19:51 AM »
3M Brushable Body Seam Sealer.
bbd564
« Reply #2 on: July 25, 2007, 03:42:37 PM »
Thank you very much.  Do you have a suggestion for applying it?  When I pulled the trunk plugs out it looked like it was applied in a bead then the plug was set into it.
« Reply #3 on: July 26, 2007, 02:42:03 PM »
Yup, that's exactly how it was done originally; I haven't used the 3M sealer in many years, but it used to be available in a cardboard tube that you used in a caulking gun.
bbd564
« Reply #4 on: July 26, 2007, 03:53:28 PM »
OK, Thanks again.  I will go to the auto paint supply shop next week see what I can get and then report back for anyone who is interested.
Jonesy
  • 1969 Camaro z28
« Reply #5 on: July 26, 2007, 07:20:47 PM »
JohnZ is right, that is how I did mine. It was still available in the tube as of 3 years ago anyway.
1969 Z28 Azure Turquoise
bbd564
« Reply #6 on: August 07, 2007, 04:59:08 PM »
I went to the auto paint supply shop today.  They did have the 3M brushable seam sealer, but he said it was available only in a quart can.  I bought a quart of it and it is a gray color and I have no idea how I would apply it to get the correct application.  I will look around a little more to see if I can find the right stuff.  At this point I will even consider the "wrong stuff"  as long as it can appear correct, if anyone has any suggestions.
bbd564
« Reply #7 on: August 14, 2007, 12:43:21 PM »
If anyone is interested here is some info on seam sealers from 3M:
http://www.camaros.net/forums/showthread.php?t=11714
It sounds like the "08505 Fast 'N Firm Seam Sealer" may be the one as it sounds like it is the correct color
« Last Edit: August 14, 2007, 12:45:16 PM by bbd564 »
Brandan
  • 1969 Camaro SS 396 X-66 M22
    • 1969 Camaro 396 SS M22
« Reply #8 on: February 28, 2009, 02:25:39 PM »
Did the original ovals get the spatter paint over it? and what about underneath the car?
Check out the 1969 ride!!!
http://www.cardomain.com/ride/676916/1
Check out the new project!!!
http://www.cardomain.com/ride/2960049
« Reply #9 on: February 28, 2009, 10:11:41 PM »
<<Did the original ovals get the spatter paint over it? and what about underneath the car?>>
Yes, the floor pan plugs were in place when the trunk was spatter-painted; they were installed after prime, on the sealer deck; the bottom side of the plug shows no paint except possible slight color overspray from the rocker guns (photo below).
Brandan
« Reply #10 on: February 28, 2009, 11:59:13 PM »
Thanks John, for some reason I remember the bottom being unpainted but couldn't remember exactly if the top was or not.
Thanks again, now if I can only find what happened to my ovals for the trunk?????   ;D ;D ;D
Brandan-
NED
« Reply #11 on: March 02, 2009, 04:04:42 AM »
Eastwood restoration products sold seam sealer in a cauking gun tube, beige in color that works perfect for the floor plugs. The product , which is what I used,  is called Hi Tek Finesse ( part CSN)  from a company by the name of The Dominion Sure seal Group. Eastwood was selling that product but has since changed to another brand according to their web site.  Bill
Bill
67Z Bench seat
69JL8 Burnish Brown
67 camaro modified ls1,6 speed, 9 "rear
m22mike
« Reply #12 on: March 12, 2009, 11:06:54 PM »
Thank you.
Read this thread.
http://www.camaros.org/forum/index.php?topic=4904.msg31987#msg31987
