Author Topic: Brake line/Fuel line clip platform???  (Read 11500 times)
mrdetails
« on: July 23, 2007, 04:31:44 PM »
Hello: On the bottom of the floor boards of my 1969 01D camaro, approx. in the middle of the door, close to the rocker pannel, is a welded on piece that forms a platform approx 1/8" off floor boards. It is about 1/2" wide and 3/4" long and has a hole in it for a screw. There is one on each side of the car. They would seem to be for a clip to hold the fuel line on the one side and the brake line on the other. Does anyone have a picture of the clip used in this application.  As always, I appreciate the help.
Thks.:
Sam
Jonesy
  • 1969 Camaro z28
Re: Brake line/Fuel line clip platform???
« Reply #1 on: July 25, 2007, 03:46:08 AM »
Okay, here you go:
1969 Z28 Azure Turquoise
mrdetails
« Reply #2 on: July 25, 2007, 01:53:25 PM »
Thank You......I couldn't find anything in the AIM about it. I thought I had seen a double "U" clip on another car but wasn't sure.
Sam
Jonesy
  • 1969 Camaro z28
« Reply #3 on: July 25, 2007, 02:41:56 PM »
I guess I should go on the other side and see what the clip for the fuel line looks like.
Flowjoe
« Reply #4 on: July 31, 2007, 02:34:26 PM »
different. ;)
it is an "M" or "W" shape..I have one sitting out right now I'll try to grab a photo.
mrdetails
« Reply #5 on: July 31, 2007, 03:56:48 PM »
Flowjoe: I thought it was a "m" shape, different that Jonsey shows. If you can get a picture that would be great. Thk's. Jonsey.
Sam
Jonesy
  • 1969 Camaro z28
« Reply #6 on: July 31, 2007, 04:26:03 PM »
I'll try to get pics tonite. I leave tomorrow for vacation for 10 days.
Flowjoe
« Reply #7 on: July 31, 2007, 08:22:19 PM »
I think this is the clip you're looking for...
From two different angles
asm69
« Reply #8 on: August 03, 2007, 01:38:28 AM »
Hope this helps.
These are pictures of original clips from a 1969 z28 built in LOS 10D. (early build)
asm69
asm69
« Reply #9 on: August 03, 2007, 01:39:28 AM »
Here are the picts.
asm69
RamAirDave
    • TheMuscleCarGuys.com
« Reply #10 on: August 03, 2007, 03:15:13 AM »
The clips that asm69 are what I have found in that location.
They are not included in the repo clip sets.
Here is an example of the repo vs originals.  The four on the outer edges are repos, the others towards the center are originals.
www.TheMuscleCarGuys.com
mrdetails
« Reply #11 on: August 03, 2007, 01:01:29 PM »
Thanks for all the help....I think i"ll do it like asm69, as I have a Los car also. 01d.
Sam
Jonesy
  • 1969 Camaro z28
« Reply #12 on: September 14, 2007, 01:48:46 AM »
Okay, here is the other side pic with the fuel and brake lines:
