Welcome to the CRG Discussion Forum!Classified ads are not allowed on the forum.
Thanks for the kind words. I have not started a resto yet but I hope to soon. I am in the process of researching what parts I need(alternator, master cylinder, etc). I also hope to build a barn to do the resto in.
I'm not sure they were cast there. Apparently there was some exchange of blocks between the locations to ensure machining compatibility.Does your block have the oil plug above the waterpump? It should have a square plug. See Pic #3 - http://www.camaros.org/pdf/flint_engine.pdfQuote from JohnZ: Flint engines (Saginaw castings) have the hole and plug and Tonawanda engines (Tonawanda castings) don't due to different machining processes for an intersection in the front of the main oil gallery; Flint tapped the hole and installed the 1/8" NPT plug after gun-drilling to create the gallery intersection at the end of the hole.
