Author Topic: Decode Help  (Read 37999 times)
rjprice
Decode Help
« on: July 20, 2007, 03:06:19 AM »
I have a car I purchased about 12 years ago and I would like to get comments on the "numbers".  Does it look right?
Body tag:
ST69    12467 NOR304192 BDY
TR 720    50APNT
03E        Z11
Vin:  124679N626575
Engine:  T0409HB
The last digits of the VIN are stamped by the oil filter and under the cowl.
Mark
Re: Decode Help
« Reply #1 on: July 20, 2007, 11:02:43 AM »
Looks fine.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
rjprice
Re: Decode Help
« Reply #2 on: July 20, 2007, 11:51:58 PM »
Thanks.  I have heard alot of conflicting information over the years about prodution data.  I just found this forum and want to learn as much as possible about my car.  I bought it in Richmond VA in 1994 and the owner said it was numbers matching.  Before I plunk down a lot of cash to restore it, I want to know what I'm starting with.
Jonesy
  • 1969 Camaro z28
Re: Decode Help
« Reply #3 on: July 21, 2007, 12:01:16 AM »
1 = Chevrolet
2 = Camaro
4 = 8-cylinder engine
67 = convertible body
9 = 1969 model year
N = Norwood, OH assembly plant
626575 = vehicle serial number sequence
Decode for body number: 304192
03E = Built the Fifth week of March.
69-12467 = Convertible.
NOR = Built in Norwood Ohio.
720 = Custom Orange Houndstooth Bucket Seats.
50-A = Lower Color is Dover White and the Convertible Top Color is White.
Z11 = Indy Pace Car accents - Convertible
In case you didnt know it's a Pace Car Convertible. :)
T = Tonawanda Engine
0409 = April 9th
HB = 350/300hp with Turbo 350 trans
1969 Z28 Azure Turquoise
rjprice
Re: Decode Help
« Reply #4 on: July 21, 2007, 12:23:23 AM »
Thanks for the info.  Does it matter that the engine date is after the car build date?
9T4Z
    • Gary's Camaro
Re: Decode Help
« Reply #5 on: July 21, 2007, 02:40:49 AM »
Most of what I've read says that the engine should be dated prior to the car build date.... but...maybe someone else can chime in.
If you had the protect-o-plate the engine # would have been stamped on that..
Gary 9T4Z
94Z rag blower 491 rwhp (now 505!)
69 Pace Car, 70RS,91Z,91RS
Re: Decode Help
« Reply #6 on: July 21, 2007, 03:06:30 AM »
Normally it does. But not in this case. The build date is inaccurate here.
rjprice
Re: Decode Help
« Reply #7 on: July 21, 2007, 03:14:41 AM »
What does that mean?
rjprice
Re: Decode Help
« Reply #8 on: July 24, 2007, 12:39:15 AM »
Is the VIN wrong for the Build date (or vice versa)?  Before I bought the car, I talked to some people at the Northern Virginia Camaro club who had seen the car and they said it was a pace car.  Is it possible the VIN was stamped on the motor to make it look numbers matching?
The car has been repainted but all of the old overspray (pre-repaint) is dover white and you can see orange under the peeling "new" paint under the cowl grill.  You can also see the old stripes under the hood edge and trunk/spoiler.
Re: Decode Help
« Reply #9 on: July 24, 2007, 04:03:16 AM »
#'s are fine.
rjprice
Re: Decode Help
« Reply #10 on: July 24, 2007, 11:54:16 AM »
Is this VIN in the database?
Re: Decode Help
« Reply #11 on: July 31, 2007, 03:56:51 PM »
No, it was not.
rjprice
Re: Decode Help
« Reply #12 on: August 01, 2007, 01:28:47 AM »
Kurt,  Could expand on why the #'s are fine?
Re: Decode Help
« Reply #13 on: August 01, 2007, 04:10:14 AM »
We have data on 14,000+ cars. Comparing you car's data to other cars built at the same time, it looks fine.
I'd be curious what the axle code is. :)
rjprice
Re: Decode Help
« Reply #14 on: August 01, 2007, 10:58:24 PM »
I'll see if I can find it.  The rear is pretty rusty.
