Author Topic: Dist question... (re: '67 327/275 AIR PG)  (Read 5797 times)
KevinK
    • Hudson Valley Camaro
« on: July 10, 2007, 03:11:17 AM »
I've got a low mileage original '67 with a 327/275hp, ...with A/C, ...with AIR, ...and PG trans.
  The distributor in the car (believed to be original) is # 1111150 6K13. The car is an 11B build with most dates mid October '66, ...so the distributor date falls right in.
   From what I have read, ...I thought the distributor would have been 1111249...?
  (The reason I checked is that I am looking at a block (for parts), ...said to have come from a '67 Camaro 275hp, ...and it too has the 150 distributor, ...which I initially was thinking was incorrect...)
   ...maybe I'm just too tired, ...but looking at Colvin's book (by the numbers), ...it seems the 150 distributor is listed for 283 applications... ???
   ...anyone know for sure??
Re: Dist question... (re: '67 327/275 AIR PG)
« Reply #1 on: July 10, 2007, 10:18:30 PM »
The distributor application chart in the '67 Chassis Service Manual shows the 150 as correct for your combination; it shows the 249 as correct for the same application, but WITHOUT A.I.R.  :)
KevinK
« Reply #2 on: July 11, 2007, 12:35:39 AM »
...Thanks John  ;)
