Author Topic: Original vented gas cap  (Read 20528 times)
GaryL
  • Marilyn and me
« on: December 24, 2005, 08:39:58 PM »
It has taken me a while to get my DZ to idle correctly. Yesterday I got some gas and the tank was pressurized. Is a vented gas cap supposed to hold any pressure? If it holds pressure could that affect how the car runs?
Gary
Re: Original vented gas cap
« Reply #1 on: December 25, 2005, 05:58:43 PM »
Yes, the "vented" cap has a pressure/vacuum valve in it, and if the tank hasn't reached the threshold for the valve, it will "hiss" when you remove the cap to refuel.  :)
william1
« Reply #2 on: October 05, 2009, 06:10:52 PM »
http://www.camaros.org/forum/index.php?topic=239.0
 vented gas cap, johnz how much pressure are we talking about, i have looked and looked but can't put my finger on it, i think but not sure,, i'm having the same problem, as soon as i bleed off the tank it accelerates fine, the tank was replaced before i got the car so i have no idea if it might be a issue with that,, was just wonderin,,, have a new cap coming....
« Reply #3 on: October 05, 2009, 10:57:52 PM »
I don't have the specs for the valve in the cap, but my original worked fine until it started leaking, and I replaced it with a reproduction about six years ago, and that works fine too.
sixt9x33rs
« Reply #4 on: October 09, 2009, 01:48:02 AM »
My cap seems to hold a lot of pressure. When I take it off just seems to pop to hard. I dont recall having this issue with the original tank.
John Z would a tank change have anything to do with the pressure at the cap?
« Reply #5 on: October 09, 2009, 03:49:36 PM »
Nope, the tank change wouldn't affect it - but a cap change might.
jdv69z
  • 69 RS Z/28 52E
« Reply #6 on: October 09, 2009, 07:12:52 PM »
My cap's original, and works  just as John describes when I refuel
Jimmy V.
Jimmy V.
sixt9x33rs
« Reply #7 on: October 10, 2009, 02:15:15 AM »
I have not changed the cap. I will check again to see if I have the same issue.
