Main Menu
Original vented gas cap
Started by GaryL, December 24, 2005, 03:39:58 PM
Previous topic - Next topic
GaryL
It has taken me a while to get my DZ to idle correctly. Yesterday I got some gas and the tank was pressurized. Is a vented gas cap supposed to hold any pressure? If it holds pressure could that affect how the car runs?
Gary
Yes, the "vented" cap has a pressure/vacuum valve in it, and if the tank hasn't reached the threshold for the valve, it will "hiss" when you remove the cap to refuel.  :)
william1
http://www.camaros.org/forum/index.php?topic=239.0
vented gas cap, johnz how much pressure are we talking about, i have looked and looked but can't put my finger on it, i think but not sure,, i'm having the same problem, as soon as i bleed off the tank it accelerates fine, the tank was replaced before i got the car so i have no idea if it might be a issue with that,, was just wonderin,,, have a new cap coming....
Quote from: william1 on October 05, 2009, 01:10:52 PM
I don't have the specs for the valve in the cap, but my original worked fine until it started leaking, and I replaced it with a reproduction about six years ago, and that works fine too.
sixt9x33rs
My cap seems to hold a lot of pressure. When I take it off just seems to pop to hard. I dont recall having this issue with the original tank.
John Z would a tank change have anything to do with the pressure at the cap?
'69 RS Z/28 65B, 711 Flat hood no spoiler, endura, 4:10 44K miles (Sold)
Quote from: sixt9x33rs on October 08, 2009, 08:48:02 PM
Nope, the tank change wouldn't affect it - but a cap change might.
jdv69z
Quote from: JohnZ on December 25, 2005, 12:58:43 PM
My cap's original, and works  just as John describes when I refuel
Jimmy V.
Jimmy V.
sixt9x33rs
I have not changed the cap. I will check again to see if I have the same issue.
