Author Topic: HELP!! Starter problems  (Read 19406 times)
vtfb68
Re: HELP!! Starter problems
« Reply #15 on: August 10, 2011, 08:42:27 PM »
 my 2cents. I have encountered twice (both BB's) a worn starter nose cone where the silinoid pushes the gear when engaged. if not checked properly this can come from a rebuilder. The first time my car kept turning over after the key was off and removed becuse the gear went PAST the flywheel and got stuck.
 I had another just grind , but had a worn cone. but you have a new (?) starter. if it has to come out again check it out. good luck.
  VT
68 08E LA RS Y2 749 L30 M35
bc69
« Reply #16 on: August 12, 2011, 03:09:05 AM »
Yes they are. Yes it is. Paper clip clearance  at tooth tip on three points all the same.
Brad
RSSS
