Author Topic: Trim adhesive  (Read 7480 times)
mrdetails
Trim adhesive
« on: June 19, 2007, 04:04:07 PM »
Would it be better to use black trim adhesive, or yellow as was used originally.
Thks.:
Sam
rat pack
Re: Trim adhesive
« Reply #1 on: June 21, 2007, 11:56:21 AM »
If you are talking about weatherstrip adhesive, use black, that is what the factory used on all of the cars I have restored. I have a 69 here that has the original paint in the jambs and there are not any traces of any adhesive being used on the door weatherstripping, which is a first for me. Also the black is less noticeable if any of it "runs" out from the edges............RatPack..........
Re: Trim adhesive
« Reply #2 on: June 21, 2007, 07:18:42 PM »
My untouched original 02D '69 has no adhesive of any kind on the door weatherstrips, and the adhesive bead used on the trunk opening weatherstrip is black.
lakeholme
  • 68-12D L30/M35
Re: Trim adhesive
« Reply #3 on: June 21, 2007, 09:25:10 PM »
John raises an interesting question:  Exactly what are you "gluing"?  Also, If you do, use black --like RatPack said-- because there shouldn't be any excess showing.
69Z28X33
Re: Trim adhesive
« Reply #4 on: June 21, 2007, 09:54:22 PM »
My 69Z is a 02D  67  67 with white stripes, I just removed the door weatherstrips, no adhesive.
mrdetails
Re: Trim adhesive
« Reply #5 on: June 25, 2007, 04:04:15 PM »
I'm gluing the trunk weatherstrip...I'll use the black
Thanks guys
Sam
