Author Topic: Can you help me  (Read 7735 times)
cbruce
Can you help me
« on: June 13, 2007, 09:19:37 PM »
Hey guys!  I just bought a 69 Z28 and I wanted to see if you could help me out with something.  While having the Engine (number matching) worked on, I took photos of the transmission so that I could research to see if it was original.  The assembly date code reads as follows P9R10AE.  It's the E at the end that is throwing me off.  I'm not sure if that means it was an exchange???  What I can assume is the partial VIN also doesn't match anything on the car it reads 70Z140801.
If anyone could fill me in on this transmission or the coding I would appreciate it.
Bjv69ss
Re: Can you help me
« Reply #1 on: December 08, 2007, 11:50:17 PM »
Someone will correct me if I'm wrong but the "E" stands for Eaton.
1969 Fathom Green
SS 350 Coupe
71 Impala Sport Coupe
Gramps69Z
  • 69 X33 D80
Re: Can you help me
« Reply #2 on: December 09, 2007, 03:31:54 AM »
The vin is not right, it should start 19N------.  Never seen an E after the transmission date.
Captain John Wykoff
Re: Can you help me
« Reply #3 on: December 09, 2007, 04:12:18 AM »
The "E" is discussed in this CRG thread:  http://www.camaros.org/forum/index.php?topic=1923.0
As for decoding the transmission, it's not the original one to your car.  It is a Muncie M20 4-speed transmission that was assembled on October 10, 1969 for a 1970 Chevelle or El Camino.     :)
Jerry@CHP
Re: Can you help me
« Reply #4 on: December 09, 2007, 03:14:53 PM »
The transmission stampings are not an original factory stamping.  Characters are not even close to what they should look like.  Someone has stamped this case.
Jerry
Re: Can you help me
« Reply #5 on: February 29, 2008, 10:43:28 PM »
That trans is from a Fremont built car... it has a Z in the Vin...
