Author Topic: 67 alternator bracket mounting bolt/stud  (Read 4624 times)
dans67camaro
« on: June 10, 2007, 12:13:56 PM »
I have a 1967 SS350 w/o ac, air pump or p/s. Does anyone know what the two fasterners are that mounts the alt. bracket to the engine? I assume it takes one bolt into the intake and one bolt in the water pump, with the water pump bolt head painted orange. Or is the water pump fastener a bolt with a stud for the bracket, similiar to the ground battery cable mount to the water pump on the RH side of the water pump, top fastener? Small detail, but no repo fasteners kits for the water pump include a bolt/stud fastener for the alt bracket at the water pump. Thanks.. Dan
gro51
  • 68 SS/RS 350
Re: 67 alternator bracket mounting bolt/stud
« Reply #1 on: June 10, 2007, 01:26:32 PM »
I have a '68 SS350 which has the same set up.  The water pump fastener is a bolt with a stud for the bracket, as you stated.  Sorry, mine is original and I don't know of a repo.
Joe
Schodack, NY
'68 SS/RS 350, M21, 3:73, Rallye Green, Black Deluxe Interior
gro51
  • 68 SS/RS 350
« Reply #2 on: June 13, 2007, 04:01:40 PM »
Dan - I found the water pump stud in the "Ground Up" catalog, pg. 33. part num. aws-301s.
Their web site:
www.ss396.com
Joe
Schodack, NY
